1972 Carter Carburetor Helicoil and also Carb storage - NCRS Discussion Boards
  • Melissa N.
    • March 1, 2003
    • 49
    In judging a carburetor, are points deducted for a helicoil?
    What is the process to store a carburetor i.e. how to prepare it for storage?
    • 43259
    Re: 1972 Carter Carburetor Helicoil and also Carb storage
    Melissa------
    Nobody could ever know if a helicoil had been installed in the vast majority of carburetor applications including the inlet fitting if that's what you are referring to.
    As far as storage, I think about the best you can do is to spray the carb with something like Pre-Lube 6 or WD-40 and place it inside a sealed plastic bag.
    • Melissa N.
      • March 1, 2003
      • 49
      Thank you Joe for that information. It is a coil of the carburetor inlet. Appreciate your response.
