Parts Book Effective Spring of 1964 - NCRS Discussion Boards
  • Dan A.
    • May 31, 1974
    • 1073
    I'm looking for a part number. Specifically from the spring of 1964 parts book, section 8.821, Corv. 63-4 hammer. Does it list 3819530 and/or 3859067? Or a different part number?
  • Mike L.
    • January 1, 1986
    • 313
    Re: Parts Book Effective Spring of 1964
    My book says hammer number is 3859067
    • Alan D.
      • January 1, 2005
      • 2053
      Dan,
      The 3859067 is the first design hammer used for 64, believe Noland's book has the print. The 3819530 was the second design and replaced the first on 1-65
      Corvair Assembly Manual December 1964 lists the first hammer. Not a direct answer, hope it helps
      • Don H.
        Moderator
        • June 16, 2009
        • 2280
        Here's a good photo of 3859067
        • Dan A.
          • May 31, 1974
          • 1073
          Thanks Mike. On the front of your parts book it is Effective on what date?
          • Dan A.
            • May 31, 1974
            • 1073
            Originally posted by Alan Drake (43261)
            Dan,
            Alan I suspect you have the order reversed. 3819530 appears in the '64 AIM and the October '64 parts book for 63-4 use. While 3859067 also appears in the Oct '64 parts book as well for 64-5 use.
            • Mark M.
              • October 21, 2008
              • 343
              I don't have a spring of spring of 64, but Chevrolet parts catalog 1938-1965 effective October 1, 1964 lists: 63-65 corvette w/ knock off wheels HAMMER ASSY.......3859067 1 6.50 Revised July 1, 1965 ( this is a large catalog). Did they issue these large parts and accessories catalogs every year?
              • David L.
                • July 31, 1980
                • 3310
                As per Chevrolet Parts History for parts sold over the counter GM # 3819530 was replaced by GM # 3859067 in June 1965.
                • Dan A.
                  • May 31, 1974
                  • 1073
                  I have that parts book, so I have that information. But thanks for trying. It's the spring of '64 parts book I'm looking for the information from.
                  Yes, these parts books were issued every year. As near as I can tell two editions a year. First in the fall effective October 1st. I think all the parts books that I have are Fall issued. I have seen parts book with Spring effective dates. I don't recall the month.
                  • Dan A.
                    • May 31, 1974
                    • 1073
                    Thanks David i have that info as well.
                    FWIW there is also a 3871308 Hammer part number in the '65 AIM.
                    • Alan D.
                      • January 1, 2005
                      • 2053
                      Dan,
                      Yes did that.
                        • 43273
                        Dan-----
                        Given that the GM #3819530 was discontinued from SERVICE in June, 1965 as Dave mentioned, any P&A catalog published prior to that date will show the 3819530 or both the 3819530 and the 3859067 from the time of the release of the 3859067 until its supersession of the 3819530. Any P&A catalog published on or after that date will show only the 3859067 until the time of its discontinuation or supersession. As a matter of fact, the October, 1964 edition of the P&A shows both part numbers and the July 1, 1965, as expected, catalogs only the 3859067. The 3859067 was available into the 2000's although I have not been able to come up with an exact date of its discontinuation.
                        If the GM #3871308 ever actually existed, it was never available as a SERVICE part.
                        • Dan A.
                          • May 31, 1974
                          • 1073
                          Dan-----
                          All of he above is known and has been discussed in previous posts. What I don't know and am looking to find our here is what is listed in the parts book issued between the October '64 issue and the October '65 issue parts books.
                          [/QUOTE]If the GM #3871308 ever actually existed, it was never available as a SERVICE part.[/QUOTE]
                          You raise one of my question regarding the 3871308 AIM hammer. What might be different about what may be a production line only part number from 3859067 which was available in service before and after the 1965 "308" hammer.
                          I also wonder why the the Oct '64 parts book lists two different part number hammers for two year ranges.
                          • Rick G.
                            • March 1, 1983
                            • 275
                            Dan,
                            In my May 1, 1964 parts book, the hammer is not listed in that section or in any other section that I can find.
                            Rick
                            IMG_4752 copy.pdf
                            • Don H.
                              Moderator
                              • June 16, 2009
                              • 2280
                              Rick
                              did you look in 5.803 ?
