1969 Corvette console data plate - NCRS Discussion Boards
  • Carl Z.
    Infrequent User
    • January 5, 2021
    • 6
    My plate is missing information. As far as I can tell it's original. Is it common to have the normal engine data missing?
    Carl
    • 43296
    Re: 1969 Corvette console data plate
    Carl
    [ATTACH=CONFIG]103849[/ATTACH]
    Carl------
    I've never seen one like this. I've got to wonder if someone removed the missing information. Otherwise, I'd say it's a "factory defect" data plate.
    • Leif A.
      • August 31, 1997
      • 3659
      An oddity for sure...
      Leif
      • Jimmy P.
        • June 24, 2014
        • 1696
        Hi Carl,
        Are you the original owner? Reason I'm asking is that I notice the remnants of black paint on the raised chrome areas of the plate. Those raised areas should be free of paint. Possible signs of an earlier restoration and maybe a replacement blank data plate. Just a thought.
        Jimmy
        1973 Convertible
        L48,M20,N40
        Mille Miglia Red/Oxblood
        • Ron G.
          • December 1, 1984
          • 866
          Anything is possible, but if it looks to be the original, than it more than likely is.
          • Carl Z.
            Infrequent User
            • January 5, 2021
            • 6
            Thought something was a miss when I bought it 42 years ago. Since then I have driven it 400 miles, just turned 67000. I did replace the arm rest and touched it up with spray die. Good catch, cleaned that up with some lacquer thinner. I hope to drive it a little more since retiring. The biggest problem with this car is carbs and gasoline. Been feeding it with aviation fuel 100 octane low lead.
            I have a plate like the one Leif attached but could not glue it on.
            Thanks guys for your responses.
