1969 Trailing Arm Date question - NCRS Discussion Boards
  • Joseph A.
    • June 20, 2012
    • 136
    I am restoring a 1969 Corvette and would like to stamp the trailing arms with a date for my restoration. Are the trailing arm dates for the left and right side the same/close to each other, or are they closer to the date of the rear spindle housing?
    • 11692
    Re: 1969 Trailing Arm Date question
    Joseph,
    Those are really two different questions.
    I have found them to be close to each other, often within a few days.
    However, since the rear spindle housing was cast before the trailing arm was ever built, the date of that part is not necessarily that similar.
    • Ron G.
      • December 1, 1984
      • 866
      "SOLID LIFTERS MATTER"
      • Patrick B.
        • August 31, 1985
        • 2009
          • 15630
          Ink stamped (like the books we borrowed from the library) with white ink on the inboard side between the bearing housing and the bushing. On the ones I have seen the drivers side (LH) is upside down and the Passenger side (RH) is right side up. They deteriorate quickly, so only low mileage cars have them.
          • Leonard M.
            • September 7, 2009
            • 236
            Here are the original ink stamps from my July 11th '72. Stamps are June 20th and June 28th. No regard to a particular position.
            • Ron G.
              • December 1, 1984
              • 866
              Terry is correct in that all Corvettes had them, but because the ink was soluble they disappeared rather quickly due to the elements. Even going thru a puddle could have washed it off. The 68-72 stamp measurement of the fonts are: Length 1 3/4" and height 3/8". Like Terry mentioned usually one stamp, the driver side is upside down and the passenger side is right side up. Also, they are typically a day or two apart. One of my own personal cars that I have owned for 47 years was just like the aforementioned configuration. If I seen the two dates upside down or right side up, I would never take a deduction because I believe that that could have happened.
              • Ron G.
                • December 1, 1984
                • 866
                I inadvertently forgot to mention that within the trail arm Stamp there are only the first three letters of the month used, no periods, and no commas.
                  • 15630
                  I am with you Ron in that I don't think right side up or upside down makes much difference. I would be so happy to see them, the orientation wouldn't matter.
                  BTW: I was remiss in failing to add earlier: For those who find this information enlightening I would direct you to the 1968-69 TIM&JG, 6th Edition, Page 229, Figs.Ch 7.34 & 7.35 and the text beside them. It should surprise no one that 1968s are different.
                  Also in the 1970-72 TIM&JG, 6th Edition, Page 231, Fig. Ch 7.25 and the text below it. I hope y'all enjoy the search as much as we do.
                  Outstanding pictures Leonard. Thank you for posting them.
