Who's rebuilding wiper transmissions now? - NCRS Discussion Boards
  • Keith R.
    • August 31, 2001
    • 675
    Tested my wipers today once again and the driver's side progressively moved outboard as it wiped and would not move back to the Park position. I pulled the wiper arm and couldn't move the splined transmission shaft by hand but when I put some pliers on it, it could be moved outboard. I suspect that the discs are not engaging as they should but I am not sure that I want to tackle a rebuild on it. Is Jay Maxwell still working on these? Are there any other recommended rebuilders of these transmissions?
    Keith MacRae
    NCRS #36692
    New Mexico Chapter
    1960 290HP FI
    2013 427 Convertible
    Shade tree mechanic and
    B-52 pilot extraordinaire
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11363
    Re: Who's rebuilding wiper transmissions now?
    Keith yes I believe he's still at it. If you tried calling and haven't heard back yet I'm sure he will. Probably taking a break.
    Rich
    • Frank D.
      • December 27, 2007
      • 2703
      Since Tom Maxwell's passing I think Jay Maxwell is basically it and I provided you his contact info via PM on that "other" forum.
      I have had some limited success rebuilding the transmissions myself but sometimes they are beyond repair.
      Mary Jo (vettegal on eBay) occasionally sells one or two rebuilt ones but not often.
      Before you send the transmission off you might try spraying some PB-Blaster down the shaft and let it sit for several hours (overnight?) and then try to gently push DOWN on the splined shaft to work the mechanism that releases the locking pawls a few times.
      Not TOO hard a push or you can damage things.
      • Keith R.
        • August 31, 2001
        • 675
        I'll give that a try Frank. They were working okay previously then all of a sudden went cattywompas (something you might expect at a PV). As you suggest, I think that the pawls are not engaging for some reason.
        Keith MacRae
        NCRS #36692
        New Mexico Chapter
        1960 290HP FI
        • Frank D.
          • December 27, 2007
          • 2703
          I should have added to put a towel in the floorboard to catch any penetrat that may drip down.
          • Keith R.
            • August 31, 2001
            • 675
            Thanks Frank. I pulled the wiper arm, nut and bezel yesterday but there's no way to get penetrant down the shaft as the splined cap that the arm fits over is staked to the end of the shaft.
            Keith MacRae
            NCRS #36692
            New Mexico Chapter
            1960 290HP FI
            • Keith R.
              • August 31, 2001
              • 675
              Some have suggested contacting Steve Hackel as he does all the wiper motor rebuilds. Heard from Steve Hackel yesterday and he does not repair wiper transmissions. He said that, like the wiper motors he repairs, wiper transmissions all end up on the same guy's work bench no matter who you hire to get it done - Capital, Corvette Central, Ecklers, Clocks by Roger, etc. I did not know this. He said to call the parts guy at Corvette Central who can help me out.
              Keith MacRae
              NCRS #36692
              New Mexico Chapter
              1960 290HP FI
              • Jay M.
                • December 1, 1991
                • 39
                Yes I still rebuild wiper transmissions, plus washer pumps and wiper motors.
                • Chris S.
                  • January 1, 2000
                  • 1068
                  Jay
                  Sending you a PM
                  Chris
                  1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
                  Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
                  1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
                  1957 Corvette - FI 3 sp - Black and Silver
