1965 body mounts missing? - NCRS Discussion Boards
  • Gary F.
    • March 1, 1977
    • 20
    I thought there are supposed to be 8 body mounts but only find 6 on this 1965 coup. Is 6 correct or should there be 8?
    Bought this 65 coupe in 1969 with 38,500 miles. It had never been wrecked. VIN 1943755105357. Has original 327ci 365 HP 4 speed. there are no #2 body mounts, the ones that usually are located under the door hinge area and accessed from inside by the kick panels.
  • Mark F.
    • July 31, 1998
    • 1601
    Re: 1965 body mounts missing?
    Originally posted by Gary Fickeisen (1324)
    I thought there are supposed to be 8 body mounts but only find 6 on this 1965 coup. Is 6 correct or should there be 8? Bought this 65 coupe in 1969 with 38,500 miles. It had never been wrecked. VIN 1943755105357. Has original 327ci 365 HP 4 speed. there are no #2 body mounts, the ones that usually are located under the door hinge area and accessed from inside by the kick panels.
    Hi Gary,
    I’m thinkin’ your ’65 would be the same as a ’67…
    My AIM shows body mounts #1, 3 and 4 are used for coupes (6 total) - #2 is added to those (used) on convertibles (8 total)
    UPC 1 ASM Sheet G1 shows the #2 Body Mount has a plug in it for a coupe (19437)
    UPC 1 ASM Sheet G3 shows the #2 Body Mount is used and bolted on a convertible (19467) thx, Mark
    thx,
    Mark
