PPG Concept DCC Acrylic Urethane - NCRS Discussion Boards
  • Dan L.
    • May 9, 2012
    • 97
    Back in 2015 my painter was able to purchase PPG's Concept DCC Acrylic Urethane paint for my 1966 rally red roadster. I'm trying to locate a supplier for some touch up work. Does anyone know where I can find a supplier? I'm hearing PP{G may have discontinued this product. Thanks!
    Dan Lynch
    54915
  • Michael S.
    • August 11, 2019
    • 135
    Re: PPG Concept DCC Acrylic Urethane
    dan, i have a body shop. i get dcc all the time. any auto body supply should be able to get this for you. peel off the label from the old paint if you have it. trick: the good suppliers tape the mix code on the inside. this tells them what tint and how much was used to mix the paint. this way if you order more they can mix it to match. if you do not have the label you can take a painted part or the whole car down to them. they have a "gun" that they can "shoot" the car with. this will also give them the formula. good luck. mike.
    • Stewart L.
      • March 1, 1980
      • 353
      • Dan L.
        • May 9, 2012
        • 97
        Thank you Mike and Stewart! I called PPG and they put me in contact with a near by supplier. Luckily, I do have the Concept paint can with the proper formula from my last touch in 2015. They ask me to bring in the can and a painted car body part so they can confirm the mixture. Another quick question - I only need a pint - is it wise to purchase an extra pint? What is the shelf life of this type of paint? Really appreciate the advice guys.
        Dan
        • Stewart L.
          • March 1, 1980
          • 353
          At $160 a pint, I would just buy what I need. By the time you mix in catalyst and thinner, a pint of color will go a long way.
          • Dan L.
            • May 9, 2012
            • 97
            Will do thanks Mike
            • Michael S.
              • August 11, 2019
              • 135
              dan, buy only what you need too. paint is very expensive. it will keep. make sure the top is closed tight. also store is a warm dry place. NOT NEXT TO THE HEATER. no sense buying more than you need. you can always get more later. also save the mix formula in your files. mike
