1963 Flywheel W/ Muncie trans. - NCRS Discussion Boards
  • Jerry C.
    • November 1, 1995
    • 741
    What flywheel will work on 63 with muncie transmission and 421 bellhousing? Thanks in advance
  • Ray K.
    • July 31, 1985
    • 375
    Re: 1963 Flywheel W/ Muncie trans.
    Jerry,
    You would need flywheel part #3791022 ( cast 021 ) which is approximately 13' in diameter with a 153 tooth ring gear.
    Ray
      • 43278
      Jerry-----
      You can also use flywheel cast GM #366861. The 366861 is actually a better flywheel. The 3791021 is gray cast iron. The 366861 is nodular cast iron, a stronger material.
