Interior Color - NCRS Discussion Boards
Interior Color
  • Ed H.
    Infrequent User
    • July 31, 1999
    • 3
    Interior Color
    Hi,
    I have a 1966 Coupe. The passenger side dash pad is bad. I ordered a new one from Ecklers. My car's interior is Trim 420=Saddle Vinyl. The new pad is a very light tan color. My interior is a very light brown. Ecklers will take it back but that doesn't help. Were there multiple color tans? Does anyone know of someone that can dye the new one?
  • Russ S.
    • April 30, 1982
    • 2163
    Re: Interior Color
    All replacement tan interior items for 66 are the wrong color. You will need to go to a local paint store and have a dye mixed to match your original interior parts. Shades of tan on various items did vary but they all were darker than what you get from vendors.
    • Michael H.
      • December 1, 1987
      • 733
      Re: Interior Color
      If you going to replace the passenger side dash pad why not do the drivers side as well then they'll match. You might check with Corvette America and see if there saddle dash pads are darker. I know I was very happy with my 67 dark saddle door panels from Corvette America and they fit perfectly.
      • Mark E.
        • April 1, 1993
        • 4607
        Re: Interior Color
        I had the same issue while restoring the light saddle interior of my '70. As Russ suggested, the best solution I found is to have a paint store mix some dye that matches the interior, and dye the reproduction parts. It's called dye, but it's just flexible paint designed for vinyl and plastic. I also used it on the steering column and other metal trim bits.
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
