Corvette Image blistering - NCRS Discussion Boards
  • Dan M.
    Infrequent User
    • May 31, 1988
    • 23
    I pulled my car out of storage last week after many years of sitting to start final prep for paint. There are blisters on the upper panel that came from Corvette Image many years ago. Did anyone find a fix for this problem short of a complete replacement? Has anyone used Duratec primer for this? Thanks
  • Frank D.
    • December 27, 2007
    • 2703
    Re: Corvette Image blistering
    Its my understanding that its contamination from the release agent used to get the part out of the mold and that CI solved the problem years ago. My painter still has a bad taste in his mouth about it from long ago when he had to repaint a surround because of the problem and still refuses to use CI panes. I don't have details on how he finally prepped the surface to deal with the issue.
    • Mike M.
      • May 31, 1974
      • 8408
      I had an identical problem about 15 years ago. we used a rotary die grinder and ground a concavity at each blister. then resin in the concavities . sold the car within a year and dont know if our treatment was long lived. there must have been over a thousand concavities. I too have heard the company solved the problem. mike
      • Stewart L.
        • March 1, 1980
        • 356
        • John R.
          • November 1, 2005
          • 433
          Stewart, what approximate timeframe was the car you mention that was sent to CI for repair and still blistered? Sounds fairly recent?
          • Donald L.
            • November 1, 1981
            • 141
            I still Will not buy fiberglass from them I had two cars that I had to totally redo and put new fiberglass on, we tried everything to stop the blistering.
            • Stewart L.
              • March 1, 1980
              • 356
              Probably within the last 2 or 3 years.
