63/64 Inboard Body Mount - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5344
    63's and 64's have an inboard body mount. The rubber cushion is 2 inches by 1/2 with a 5/8 hole in the center. I can not find these anywhere. They are available in a kit, but the bolt is configured incorrectly.
    Has anyone seen this size rubber cushion anywhere?
  • Frank D.
    • December 27, 2007
    • 2703
    Re: 63/64 Inboard Body Mount
    Unlike the leaf spring cushions Harry, I couldn't find anything but the inner mount "kits" and yes the bols provided are not correct, for one very apparent thing, the tip of the threaded shank protruding under the car is not tapered as the original bolts are...
    • Richard G.
      • July 31, 1984
      • 1718
      I had to purchase the mounts separate from the standard replacement mount kits for the C2.
      Might try this link. It's Corvette Central Sales on Ebay.
      • Harry S.
        • July 31, 2002
        • 5344
        https://www.ebay.com/i/373219694885?...AaAheaEALw_wcB
        Rick, that's what I have and the bolts are incorrect. The tip is flat, not pointed as pictured. The headmark is a U, I believe it should be M or ​TR
          • 6956
          Harry, do you know the length of the bolts, I may have a couple.
          • Harry S.
            • July 31, 2002
            • 5344
            Total length looks like two inches.
