63 L84 oil pan - NCRS Discussion Boards
63 L84 oil pan
  • Todd L.
    • November 25, 2020
    • 298
    63 L84 oil pan
    Hey guys,
    The NCRS technical information manual and judging guide (6th edition) states that the L76 and L84 oil pan is six quarts with two dimpled depressions on each side. Everything I have seen out there with the 6 qt, 13-1/2" long sump has three dimples on the drivers side, and two on the passenger side, similar to the 10-1/2" long sump L75 pan. Am I missing something here? I believe the GM part # was 359942. I would appreciate the help with this.
    Todd
    • 43284
    Re: 63 L84 oil pan
    Originally posted by Todd Lawson (67502)
    Hey guys,
    Todd
    Todd------
    The 1963 L-76 and L-84 oil pan was part of a 6 quart system. The pan had 3 vertical depressions on the left side and 2 on the right side.
    The original part number of the pan was GM #3820001. The 359942 is a 1975 replacement for the original. It is identical except that the front gasket radius is 2-3/8" instead of 2-1/4" for the 3820000. A 1975-79 gasket set must be used with the 359942 oil pan.
    • Todd L.
      • November 25, 2020
      • 298
      Re: 63 L84 oil pan
      Thanks Joe,
      So are you saying the judging manual is incorrect, since it states only two dimples on each side?
      • Michael J.
        • January 27, 2009
        • 7169
        Re: 63 L84 oil pan
        I hear rumors the manual will soon be updated.......
          • 43284
          Re: 63 L84 oil pan
          Thanks Joe,
          Todd------
          If that's what it says and if we're talking about the same features described as "dimples", then I'd say it's incorrect. I've not seen a pan with 2 "dimples" on each side but I've certainly not seen everyone ever made.
          • Michael J.
            • January 27, 2009
            • 7169
            Re: 63 L84 oil pan
            Well, I have 1 '63 and 3 '64 L84s, I just went to look and all of them have oil pans with 2 of the long depressions or dimples on each side of the pan. So they must exist as the TIM&JG states, all have been through NCRS judging on multiple levels as well and no deductions for the oil pans.
              • 43284
              Re: 63 L84 oil pan
              Michael------
              I think there must have been a change in the configuration of the GM #3820001 which added the left side "dimple" sometime during the years of its manufacture (1963-1974).
              I have a known-original, 1969 GM #3820000, the 5 quart pain, and it has 3 "dimples" on the left side and 2 on the right. I now wonder if early versions of the 3820000 had only 2 "dimples" on each side?
              • Michael J.
                • January 27, 2009
                • 7169
                Re: 63 L84 oil pan
                Michael------
                I think that is correct Joe, I remember when one of my '64s was being restored and the engine guy said he had to look long and hard to find the original '64 L84 oil pan.
                  • 43284
                  Re: 63 L84 oil pan
                  Michael-----
                  After 1964 the "6 quart" pan was used only for 1965 L-76,and L-84, MAYBE some 1965 L-79, all without power steering, of course. Then, it was not used again until it was used for early 1970 LT-1 and 1970-72 ZR-1. It was never used again after 1972.
                  Does anyone have a car with one of the above that they are reasonably sure it has its original oil pan? Maybe we can determine about when the change occurred.
                  Also, does anyone have a 1963-64 with the "5 quart" pan that they are reasonably sure has its original oil pan? I'm very interested to know what number of "dimples" (actually, impressed vertical ribs) they have.
                  • Harry S.
                    • July 31, 2002
                    • 5345
                    Re: 63 L84 oil pan
                    Here ya go. 2.25 Inch opening. This pan has the nut welded on the inside. I know the one on my April 63 has the nut plate welded inside, but I can't get to car to look. It's in storage for the winter.
                      • 43284
                      Re: 63 L84 oil pan
                      [ATTACH=CONFIG]103477[/ATTACH]
                      [ATTACH=CONFIG]103478[/ATTACH]
                      [ATTACH=CONFIG]103479[/ATTACH]
                      [ATTACH=CONFIG]103480[/ATTACH]
                      [ATTACH=CONFIG]103481[/ATTACH]
                      Harry------
                      Do you know what year Corvette this pan came off of?
                      • Harry S.
                        • July 31, 2002
                        • 5345
                        Re: 63 L84 oil pan
                        Harry------
                        Nope, but I'm sure it's not a 63. If I can get to my April 63 I'll let you know what is there. I do believe it's a 3820000.
                        • Harry S.
                          • July 31, 2002
                          • 5345
                          Re: 63 L84 oil pan
                          Picture of right side just after paint. I'll look for the left side. This is the April 63 with the nut plate welded in the pan. Making it an early pan.
                          • Dick C.
                            Past NCRS President
                            • November 1, 1995
                            • 454
                            Re: 63 L84 oil pan
                            1965 L79 42000 miles (204XX)
                            Dick Capello
                            New England Chapter/Mid Atlantic Chapter
                            Past NCRS President
                            Past Region 1 Director
                              • 43284
                              Re: 63 L84 oil pan
                              [ATTACH=CONFIG]103487[/ATTACH][ATTACH=CONFIG]103488[/ATTACH][ATTACH=CONFIG]103489[/ATTACH]
                              Dick------
                              Good! So, the "5 quart" pan had the 3 left side "dimples" at least as far back as 1965.
