I am trying to make sure the old GM oil pump I have is the right one for a 70 LT-1.  Is the GM production oil pressure spring color coded or otherwise identifiable?  Also what is the correct one piece oil pan gasket for the original 1970 timing chain cover?
					GM SB oil pump spring
	Tags: None
- Top
Re: GM SB oil pump spring
Patrick------
The spring used for the LT-1 oil pump had a stripe of white paint and was of 21 coils. GM #3848911. The paint stripe may or may not be discernible after long use in the pump.
There is no 1 piece oil pan gasket available from GM for pre-1980 small blocks. The Fel-Pro # is OS34509T (blue) and the Mahle # is OS32458 (black).In Appreciation of John Hinckley- Top
