Another member suggested I might ask: For U69 Radio Corvettes, is it common to see an extra un-threaded hole near the threaded hole used for "to the frame" grounding straps? I found this on the crossmember for the exhaust clamp ground straps (on both sides) as well as for the frame location for the power antenna ground strap; 1965 Corvette made in March.
p. s.
There's only one hole on each of the engine mounting "horns" up front.
p. s.
