Original or older replacement? - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 7053
    Re: Original or older replacement?
    Originally posted by Alan Drake (43261)
    Purchased a box of 3831586, cushions, they all have "ABF" and no pn. PS, if having the car judged you may get a deduct for having "fat" cushions, we have gotten used to the repo's. ...
    Alan,
    Are the repro rubber bushings known to be shorter or less wide than the GM bushings? And do people think the GM service replacement bushings were taller and/or wider than the original GM production bushings?
    Gary
    • Alan D.
      • January 1, 2005
      • 2046
      The LI one is h=1.20, dia=1.980 while the GM service is h=1.23, dia=2.00 Center holes are the same.
      Really minor differences however when installed the GM ones look fatter, perhaps they are a softer compound?
      While the LI one just looks smaller in diameter, however looks can be deceiving. Was surprised when I measured the two
      • Gary B.
        • February 1, 1997
        • 7053
        #18
          • 43248
          #19
          Alan------
          I expect the main difference between the reproduction cushions and the GM is the durometer of the rubber compound used.
          The difference in measurement between the two bushings you describe I'm sure would be within the allowable specs even for the GM bushings.
            • 43248
            #20
            [ATTACH=CONFIG]103137[/ATTACH][ATTACH=CONFIG]103138[/ATTACH][ATTACH=CONFIG]103138[/ATTACH][ATTACH=CONFIG]103139[/ATTACH]Gary here’s some pick took of some 90s vintage bushings, and washers one with the arrow head logo is from a 64 and the one with the made in Canada is a serv replacement from GM. the leaf spring cups 2 are reproduced and one is original.the car one is from long island Corvette which appears to spot on ,other than the plating.
            Edward-------
            These parts were used on Corvettes right through 1982. It's very possible, even likely, that the Canadian-manufactured parts were used on later C3's. I'd opine that when the SERVICE parts changed to the Canadian-manufactured and stamped, the PRODUCTION parts changed about the same time, assuming, of course, that the change happened prior to 1982.
