If you have ever removed a brake booster on a 1972 (or related C3) 4-speed... - NCRS Discussion Boards
  • Larry M.
    • December 1, 1986
    • 541
    ...please let me know how you did it.
    Underdash access to the nut on the upper, outboard booster stud is the problem. I can see the other three nuts, and can connect a socket to them with a long extension and swivel joint, but that particular one is hidden behind the neutral safety switch and it's linkage. I'll remove the driver's seat so I can squeeze in, and I can easily remove the steering column if need be.
    I've seen posts about removing the upper and/or lower dash pads but I'm reluctant to attempt to move either of them; the upper for concerns about it being brittle and breaking on removal, and the lower because I remember it being a difficult R&R due to the speedo and tach connections as well as the gauge lights. I even had to laugh at one post where when the booster was reinstalled, that one offending nut was omitted.
    Thanks for any tips.
    Larry
  • Lawrence M.
    • February 1, 1995
    • 404
    Re: If you have ever removed a brake booster on a 1972 (or related C3) 4-speed...
    Larry,
    It's been 18-20 years since I changed the leaking booster on my '69. Did not have to remove the column or any dash pieces. Removing the seat and laying on your back helps a lot. If you don't wear glasses use a pair of safety glasses in case a socket or tool falls on your face. That one nut is done mostly by feel. I remember one of the nuts only being turned maybe a 1/4 turn at a time. It is a bonus if you have a helper to get you a another tool you decide you need instead of trying to get out from under there once you are "in place". It can be done, but it is no fun. Good luck on the project.
    Larry
    2002 Z51 Convertible
    1969 L46 Convertible
    • Ed H.
      • November 19, 2015
      • 192
      UGH!!! and again, UGH!!!
      DAMHIKT, but check the clevis pin that attaches the rod to the brake pedal to ensure it is long enough that the clip can be refit...
      Some electrical tape wrapped around the 'u' joint you will most likely be needing will stiffen it up considerably, and make it much easier to get the socket onto the nuts.
      Have some of your favorite pain pills handy.
      I feel your pain.
      • Larry M.
        • December 1, 1986
        • 541
        Larry and Ed,
        Thanks; were either of your cars 4-speeds? Did the neutral safety switch remain in place, or did it need to come out?
        I'm definitely not looking forward to this job, and both your comments back up my trepidation.
        Larry
        • Lawrence M.
          • February 1, 1995
          • 404
          My car is a 4 speed. I do not remember removing the neutral safety switch.
          Larry
          • Larry M.
            • December 1, 1986
            • 541
            Thanks, Larry!
            • Ed H.
              • November 19, 2015
              • 192
              Likewise.
              I also call to your attention that McMaster Carr is a source of a device you hopefully won't need, but... It is a hinged 'die' that can be clamped around the 'good' threads and 'unscrewed', thereby restoring the first few threads that got damaged by a cross-threaded nut. DAMHIKT either! And, seriously, check the clevis pin. If it is too 'short', squeeze the end of the booster rod such that the clevis pin is proud enough that the clip will secure it.
              • Harmon C.
                • August 31, 1994
                • 3228
                I had the dash,steering column and pedals out and still could not put that nut on with a socket.
                Lyle
                • Larry M.
                  • December 1, 1986
                  • 541
                  Lyle,
                  Thanks. Am I reading you correctly - you were able to get the nut off, but not back on?
                  • Larry M.
                    • December 1, 1986
                    • 541
                    Ed,
                    Thank you for that clevis pin tip. I'll be installing a new booster, so repairing damaged threads shouldn't be an issue.
                    Larry
                      • 11693
                      I've done it with everything in place including the seat, but I can tell you it is THE worst job on these cars.
                      The nuts are locking (deformed thread) type, and you will get about 1/32 of a rotation with your ratchet each time you try it.
                      Usually we're laying on our back and looking up, sometimes with a headlamp on.
                      You will need quality U-joint connectors to make this work.
                      • Larry M.
                        • December 1, 1986
                        • 541
                        Patrick,
                        Thanks for the encouraging news that it can be done with dash, etc, in place. Doing the math, if the stud thread count is 18 per inch, and 3/4" of threads need to be spanned, that's about 13 threads; times 32 to span a full thread, that's 416 ratchet movements to get a nut off; times 4 for all nuts equals 1664 motions. That sounds depressing and painful and like a gateway to carpal tunnel. It's a bit less depressing if a 1/4 turn of the ratchet can be accomplished each time.
                        My plan is for me to be on my back under the dash, using one hand (not sure which one yet) to stabilize the socket and u-joint swivel onto the nut, and the other hand stabilizing a very long extension rod while my wife operates the air ratchet attached to it.
                        Sounds good in theory, but it still all depends on being able to get the socket onto the nuts. Obviously since all of you who have replied have been able to do it, I'm encouraged to stick it out through the pain. Not looking forward to it, but encouraged.
                        Larry
                          • 11693
                          You won't be able to use an air ratchet. The u-joints will be at too severe of an angle, and it will bind. Trust me.
                          And, there is no way you will get 1/4 turn at a time, for the same reason. Thus the need for a couple of high quality u-joint connectors.
                          Attached is a photo of my son doing this job.
                          • Larry M.
                            • December 1, 1986
                            • 541
                            Well.
                            Rats.
                              • 15634
                              I see. Get the young ones to do it.
