1972 Lt1 convertible w/AC restoration Intake manifold bolts - NCRS Discussion Boards
  • Fred H.
    • December 4, 2019
    • 314
    Presently my 72 LT1 aluminum intake manifold is attached with 12 shoulder bolts, the example in the TI & Judging guide shows it should be assembled using bolts with separate washers. I'm assuming the TI & Judging guide is correct? Looking for photos of correct LT1 manifold bolts if possible.
    Fred Hickey
    Care taker of Top Flight 72 LT1 C60 Convertible #26756
    • 15618
    Re: 1972 Lt1 convertible w/AC restoration Intake manifold bolts
    Fred,
    You want to restrict your request for pictures to 1972 LT1. I believe the bolts attaching the front lifting bracket will have a different head configuration than the other attaching fasteners.
      • 11674
      Fred,
      I believe that the ones holding the wire supports will also differ in head marking.
      Typically there are at least 3 different bolts used on an intake if you count configuration and headmarks as differences.
        • 15618
        Good catch Patrick. I forgot about the wire supports late last night. The TCS Solenoid mount will have a stud on the bolt head as well. I know who can provide some pictures, but it will take some time for me to get this done.
          • 11674
          Yes, I figured the stud was "obvious" but...
          • Leonard M.
            • September 7, 2009
            • 236
            Fred, Read through this 2012 post with pictures of an original 1972 LT1.
            72 LT-1 Intake Manifold Bolt Headmarks (ncrs.org)
            • Fred H.
              • December 4, 2019
              • 314
              We appreciate everyone's input, very helpful.
              Thanks Fred
              Fred Hickey
