C2 semi gloss paint ? - NCRS Discussion Boards
  • Robert P.
    • October 19, 2019
    • 317
    Hi, ready to paint some of the pieces for my 66 roadster that are listed as semi gloss in the judging manual and have a ?.
    I have semi flat #1613 krylon which to me looks closer to the parts in the manual and a semi gloss which almost looks like gloss black. Is one more correct than the other
    thanks inadvance Bob
  • Ron G.
    • December 1, 1984
    • 865
    Re: C2 semi gloss paint ?
    Robert,
    GM used a semi-gloss black paint, part number 1050104 which is now discontinued. However, the good news is you can still buy this paint from Melrose Corvette. Their number is: (815) 758 - 2783. The formula has changed, but it is minor and may not be noticeable to an untrained eye.
    - Ron
    "SOLID LIFTERS MATTER"
    • Michael M.
      • February 1, 1993
      • 604
      Depending on what your painting Krylon #1613 should be fine. Eastwood makes some good semi-gloss color matches also.
      • Mike T.
        • January 1, 1992
        • 568
        Robert - Is that an old can of Krylon #1613? Krylon reformulated that popular number some years ago and it hasn't been the same since. The commonly available Krylon Satin Black isn't that good, in my opinion. Some of us have found that the Krylon 'Industrial' #1613, is closer to what we're used to seeing but even it's a bit 'flatter' than I recall.
        Mike T. - Prescott AZ.
        • Robert P.
          • October 19, 2019
          • 317
          I bought a case of the 1613 semi flat industrial lacquer , looks a little to flat for me
          regards Bob
          • Owen L.
            • September 30, 1991
            • 882
            What is the opinion of SEM Trim Black #39143?
            • Mike T.
              • January 1, 1992
              • 568
              Owen - While I still like the Industrial Krylon #1613, that 'extra flatness' doesn't work for me like the old formula does so on certain items I prefer the SEM Trim Paint you listed, #39143. My neighbor had just pulled his steering column on his 66 L72 Coupe and had paint on order but was hoping to get it painted and resinstalled sooner rather than later so I offered up both the Industrial Krylon #1613 and the SEM paint, #39143. He wound up using the SEM and said it had just a bit more 'semi-gloss' to it and looked nicer.
              • Leif A.
                • August 31, 1997
                • 3641
                I agree with your assessment, Mike. I did the same...bought a six-pack case of #1613. While a very nice product, a bit less satin appearing than I remember.
                Leif
                • Mark S.
                  • July 31, 1983
                  • 660
                  There are other alternatives like John Deere Blitz Black, etc. You may want to key into the archives to see this discussed in the past. Stay Safe!
                  • Gerard F.
                    • June 30, 2004
                    • 3806
                    Robert,
                    On my 67 with black interior, I used SEM Trim Black 39143 for interior trim (Glove Box, console, etc) as well as exterior rocker panels, frame touch-ups. It is a little tougher paint than the Krylon #1613.
                    Look here for a another post on trim black
                    https://www.forums.ncrs.org/showthre...ighlight=39143
                    Jerry Fuccillo
                    • Paul D.
                      • September 30, 1996
                      • 491
                      I have used the Blitz Black and really liked the look. I won't claim it is "correct", but it gave a very good, satin looking sheen in my opinion. I got mine years ago, so not sure of availability. I have used both spray cans and mix and spray through a gun. Sprayed out well even considering my amateur skills.
                        • 11659
                        John Deere Blitz Black also changed formulas several years ago, and is not the same sheen/color it used to be.
                        • Mark S.
                          • July 31, 1983
                          • 660
                          I use an implement semi gloss black paint and it is a perfect match.
                          • Daniel Y.
                            • September 30, 2002
                            • 185
                            You are using the best paint in my opinion. only place you can buy it is Granger now I think.
                            Dan Young
                            65, 67 Duntov x2
                            66 bowtie x 2
                            71 LT1 TF
                            90 ZR1 McCelland
                            03 Anniverary
                            06 Z06
                            • Gary B.
                              • February 1, 1997
                              • 7045
