67 BB radiator question - NCRS Discussion Boards
  • Orjan S.
    Infrequent User
    • July 31, 2003
    • 20
    Hi.
    I'm going to restore my radiator.
    I discovered that someone has soldered a pipe with a petcock instead of the brass plug that should be on cars made before January 1967.
    Does anyone have a photo of what it should be like?
    How should the plug be mounted?
    Is there a "nut" on the inside of the radiator?
    What size should it be on the brass plug?
    Orjan
  • Daniel Y.
    • September 30, 2002
    • 186
    Re: 67 BB radiator question
    I appreciate your attempt to restore that radiator but after you fix that issue and recore you'll have pretty close to the price you would pay at Dewitts and they are damn near identical. if you order one - make sure you tell them to make the cut outs on the bottom the same as the top and paint gloss. usually I have to repaint with a higher gloss - but its worth it knowing it will perform as new
    Dan Young
    65, 67 Duntov x2
    66 bowtie x 2
    71 LT1 TF
    90 ZR1 McCelland
    03 Anniverary
    06 Z06
    • Rich G.
      • August 31, 2002
      • 1405
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11364
        Orjan, All BB radiators I've worked on had the petcock so not sure about that female fitting but I'd think it would be just soldered to the bottom tank with no internal nut. Not sure of size.
        Rich
        PS Gents.... Orjan is in Sweden so I think that's why he's repairing what he has. Shipping over the water can get really expensive, along with customs delays and duties.
        • Tom E.
          • June 1, 2019
          • 448
          Orjan,
          There are several original 1967 Harrison radiators on eBay with a few good photos. Perhaps looking at them will help.
          here is one of the 2 I saw.
          Tom
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11364
            The more I think about this, weren't the radiators identical but some time in production it used the pipe plug, and some used the petcock?
            So wouldn't the female threaded fitting in the bottom driver side of the tank be the same for either?
            Rich
            Here's a Dewitt's restoration radiator I got for a '67 restoration I did 8+ years ago. Sorry last photo of the petcock is a bit blurry and doesn't really show the female fitting very well.
            below
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11364
              Originally posted by Tom England (65936)
              Orjan,
              Tom
              Here's a close-up of one of those photos showing the female fitting.
              • Daniel Y.
                • 186
                I don't believe this radiator is original 67
                the holes should be the same as the top
                Dan Young
                65, 67 Duntov x2
                66 bowtie x 2
                71 LT1 TF
                90 ZR1 McCelland
                03 Anniverary
                06 Z06
                  • 43279
                  Originally posted by Orjan Simonsson (40539)
                  Hi.
                  Orjan
                  Orjan------
                  Are you sure this is not a simple case of someone having removed the brass plug and installed a petcock?
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11364
                    Orjan------
                    That's what I was thinking also. Same radiator, different pieces that thread into it.
                    • Orjan S.
                      Infrequent User
                      • July 31, 2003
                      • 20
                      Gentlemen.Thanks for all your posts and photos.I have been in the radiator shop.They do not have a 100% correct core for the radiator and the tanks must be adjusted.I think you'r right Joe, Someone replaced the plug with a pipe and a petcock.I have a "correct" radiator from DeWitt but it is not 100% correct.Therefore, I wanted to restore my original radiator.I know DeWitt had radiator cores on their website but I can not find it on their website anymore.
                      Orjan.
