C-1 Fuel Filter Unit - NCRS Discussion Boards
  • Gary H.
    • June 30, 1980
    • 155
    The glass bowl filter assembly on C-1 carbureted cars has a metal cover!
    In the Judging Guides the material for the cover is described as being die cast zinc ('53-'55 manual), die cast pot metal ('56-'57 & '58-'60 manuals) and finally die cast aluminum ('61-'62 manual).
    So the question: which one is correct?
  • Loren L.
    • April 30, 1976
    • 4104
    Re: C-1 Fuel Filter Unit
    Which one do you care about?
    • Gary H.
      • June 30, 1980
      • 155
      All of them, they must have used the same material every year.
      • Loren L.
        • April 30, 1976
        • 4104
        Is it a "requirement" that they use the same material every year? It wouldn't appear so, based on your descriptions.........
        • Jim L.
          • September 30, 1979
          • 1816
          Gary,
          Die cast zinc and die cast pot metal are pretty much the same thing, although the exact metallic composition varies.
          Pot metal is a horrible material in that it will always creep in such a way as to relieve applied stress. That translates to leaks with the older filter covers.
          So, if you have a choice, the '61-'62 die cast aluminum lid is a much better technical choice.
          Jim
          • Gary H.
            • June 30, 1980
            • 155
            That's what I don't know, thus the question.
            • Gary H.
              • June 30, 1980
              • 155
              Thanks Jim, my exact feelings on the pot metal not being very stable.
              What I'm not sure about is if the people that put the judging manuals together were describing the cover the best they could and just guessing what the material was or if they really know.
              I'm not judging their intent just trying to find out if there is a difference between a '53 cover and say a '62 cover..
              • Jim L.
                • 1816
                Understood and appreciated, Gary. I don't know the answer.
                • Gary C.
                  Administrator
                  • October 1, 1982
                  • 17768
                  Gary,
                  IIRC none of the 56-7 carb fuel line filters I've had were aluminum.
                  And were casts as aptly described by Jim Lockwood.
                  Gary
                  NCRS Texas Chapter
                  https://www.ncrstexas.org/
                  • Steven B.
                    • June 30, 1982
                    • 3997
                    Agree Gary.
