7029204 Throttle Plate ID - NCRS Discussion Boards
  • Greg L.
    • March 1, 2006
    • 2291
    Well guys I seem to have myself in a bit of a situation here. I found a date matched 29204 carb about 10 or so years ago and I'm just getting around to restoring it now. The problem I was told is that the throttle plate is wrong(from a 68 SBC). The reason I questioned it is because it has a small block throttle lever which I just recently discovered is different than the big block. The rest of the carb looks correct including the jets, metering rods, etc so what I need now is a correct throttle plate or even one that will work for now until I find a correct one.
    My question is how can one positively ID this 396/427 throttle plate assy and in the mean time which throttle plates could I use until I find a correct one? Also where in the heck would a guy start to look for something like this. Whole carbs come up from time to time but this throttle plate might be a little more challenging.... Heck I'm not even sure what P/N to search for this piece.
  • Mike M.
    • May 31, 1974
    • 8407
    Re: 7029204 Throttle Plate ID
    i'd call all the guys who restore carbs--chuck smith, bob kunz, and anyone who rebuilds carbs in the Driveline. mike
      • 43273
      Greg------
      I'm going to assume that you are referring to the throttle body assembly when you say throttle "plate". The throttle body assembly for your application was GM #7036620. Unfortunately, it was discontinued without supersession in April, 1975 and will be very difficult to locate. Q-Jet throttle shafts or levers were never available separately from GM, only as part of throttle body assemblies.
      • Greg L.
        • March 1, 2006
        • 2291
        Thanks guys. I'll try Chuck or Bob and see what advice they might have. Since the throttle levers were never offered as individual parts I might have better luck searching for the lever part number in hopes that it is still with it's original throttle body assy.
