Lower radiator hose blew off today - NCRS Discussion Boards
  • Keith R.
    • August 31, 2001
    • 660
    Re: Lower radiator hose blew off today
    Well, I understand that Danny but worm gear clamps don't do so well for flight judging as I understand it.
    Keith MacRae
    NCRS #36692
    New Mexico Chapter
    1960 290HP FI
    2013 427 Convertible
    Shade tree mechanic and
    B-52 pilot extraordinaire
    • Keith R.
      • August 31, 2001
      • 660
      I put Permatex Right Stuff 90 minute RTV on it this afternoon and will do a test run tomorrow. I will let you know how it goes.
      Keith MacRae
      NCRS #36692
      New Mexico Chapter
      1960 290HP FI
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11323
        #18
        Keith.... Yes if getting judged..... a hit. Yours is a '60 correct? IIRC Lower hose uses Corbin, Upper hose uses Tower.
        Originally posted by Tom England (65936)
        Keith,
        I would recommend not
        Tom, I Agree.... that's why I like the Permatex liquid or #2 paste, Indian Head shellac, etc. I've used that stuff for 40 years and never let me down. Yes brand new pumps and fitting were dry but old stuff needs "reinforcement" sometimes, that's why I use the gooey stuff which is semi-non hardening but really holds. PIA to remove the hose later but as mentioned I usually cut them off as they're being replaced anyways.
        Now that '60 that had the "combustion gasses in the coolant" problem in my earlier link, no matter what!..... It blew off, Even a couple of worm clamps couldn't keep that doggone hose on. I'm still baffled why the 13lb cap(tested good) didn't release before the hose blew off. One of life's mysteries to me.
        But Keith, just make sure that RTV is cured real good before you try it. Maybe it'll work ok. We'll see. I just have a uneasy feeling why all of a sudden you're having this issue. For peace?/piece? of mind, maybe take a trip to NAPA or HF and get one of these and do a quick test. I don;t mean to scare you but JIC.
        NAPA Kit (comes with fluid)
        Harbor Freight Kit (fluid separate cost)
        Fluid
        To tell you the truth, I'm not sure that it was ever there. As Rich Mozzetta said, these pumps perhaps never had the ring around the neck. I've got a spare pump and will take a look at that.
        I have seen so many pumps without the sealing ring/bead. Seems the old 50's 60's original pumps I've rebuilt don't. Later ones maybe do. I don't know why some do and some don't. But... I know someone who worked at the pump casting foundry when he was young(he's old now!) making these pumps(maybe it was Saginaw?). I'll shoot him a email and ask again. He's in California so it may take a while.
        Rich
        • Danny P.
          • June 30, 2002
          • 341
          #19
          Keith by the photos , there's a blue Fel Pro oil pan Gaskets and Permatex RTV that showing that not going do so well in flight judging ether, it going to take a hit... ?
          • Keith R.
            • August 31, 2001
            • 660
            #20
            Yes, for sure Danny but I'm willing to take the hit. It's a NORS pan that has plagued me with leaks at the front and rear of the pan. I may have to pull it again if the leaks don't stop but once they do, I'll paint the gasket orange to disguise it somewhat.
            Originally posted by Danny Pantuso (63794)
            Keith by the photos , there's blue Fel pro oil pan Gaskets an but d Permatex RTV that showing that not going do so well in flight judging ether, it going to take a hit... ?
            Keith MacRae
            NCRS #36692
            New Mexico Chapter
            1960 290HP FI
            • Keith R.
              • August 31, 2001
              • 660
              #21
              Thanks Rich. That sounds like a good precaution to take just in case.
              Keith MacRae
              NCRS #36692
              New Mexico Chapter
              1960 290HP FI
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11323
                #22
                Keith did you get the pan gasket with the "thick" front seal integrated into the one piece? The part#'s for both thick and thin are in the archives here somewhere. IIRC Joe Lucia posted them. I'll see if I can find it..... This thread might help
                If your pan is a NORS (repro) it'll have the deeper front spacing to the block.
                Rich
                • Keith R.
                  • August 31, 2001
                  • 660
                  #23
                  Its a Felpro 1880 Rich which is the correct one I believe for the newer pans.
                  Keith MacRae
                  NCRS #36692
                  New Mexico Chapter
                  1960 290HP FI
                  • Harry S.
                    • July 31, 2002
                    • 5302
                    #24
                    Here is the Mahle one piece for the early pan.
                    • Keith R.
                      • August 31, 2001
                      • 660
                      #25
                      I like the fact that it is black. I think Mahle was the first gasket that I tried.
                      Keith MacRae
                      NCRS #36692
                      New Mexico Chapter
                      1960 290HP FI
