C1 engine support bracket - NCRS Discussion Boards
  • Joe P.
    • October 4, 2007
    • 209
    I had some pitting on my bracket around the attaching holes and the coolant flow holes. I purchased a replacement from Corvette Central. When I opened the box, I was quite surprised at the quality of the bracket and very disappointed with the excessive stretch marks and deep groves. I quickly returned it and attempted to order a GM Restoration quality bracket from Paragon, and this time before I bought it. I asked about the quality and got the same response, about the quality, "the tooling is 60 years old what do you expect!"
    A friend suggested to get the original bracket I had repaired; the bracket came back from a local machine shop. The cutout the sections around the holes and welded in a new piece of metal on both sides and ground them flat. The overall shape is great the holes line up.
    My question is regarding the strength of the welded strong enough to hold the engine weight and torque? Should I use the repaired bracket, or should I search for a good used bracket?
  • Joseph S.
    National Judging Chairman
    • March 1, 1985
    • 926
    Re: C1 engine support bracket
    Joe, I might have an NOS bracket. Let me look tonight when I get home!
    • Joe P.
      • October 4, 2007
      • 209
      Thanks Joe, please PM me if you find it.
      • Joe P.
        • October 4, 2007
        • 209
        Any thoughts on the strength question? will the welded metal that was put in place be strong enough to avoid any potential failure?
        • Leif A.
          • August 31, 1997
          • 3651
          Done correctly, a weld is typically stronger than the metal around it.
          Leif
            • 15631
            Metallurgical analysis of the quality of the weld can be done short of sample destruction, but it requires specialized x-ray equipment among other tools. I would suggest nondestructive testing would be expensive; perhaps prohibitively so. Destructive analysis (extracting a sample) can also be done using specialized equipment, but in this case is hardly productive.
            The skill of the welder (are they certified?) is your best option if you wish some assurance before going forward.
            Disclaimer: I only spent four years in a metallurgy lab more than half a century ago. Procedures could well have changed since then (not to mention my memory), and someone currently involved in the science would likely have better suggestions.
            • Terry D.
              • May 31, 1987
              • 2697
              I would buy a new one, why worry every time you drive the car!
              • Tom E.
                • June 1, 2019
                • 448
                • Keith R.
                  • August 31, 2001
                  • 675
                  I had the same pitting but filled them with JB Weld and filed them flat. Had no issues or leaks after installation with Permatex #2 other than the lower radiator hose blew off after shutdown! That JB Weld is tough stuff and rated to 500 degrees.
                  Keith MacRae
                  NCRS #36692
                  New Mexico Chapter
                  1960 290HP FI
                  2013 427 Convertible
                  Shade tree mechanic and
                  B-52 pilot extraordinaire
                  • Joseph L.
                    • July 26, 2012
                    • 162
                    If the question was whether a welded part is as strong as an unwelded part, the answer is generally NO. The base metal, the weld material and the heat affected zone will have different mechanical properties. It is more apparent in higher carbon steels and alloy steels; not so much in low carbon steels. Uncontrolled cooling and the resulting microstructure of welding are to blame. That is what heat treatment is all about (normalize, austenitize, quench, and temper), and vital for tool steels. Try using a chisel that has not been tempered and watch it chip and crack. Watch Forged In Fire and get a small insight into heat treatment.
                    Joe
