Diehard 1150 12 volt battery jumper - NCRS Discussion Boards
  • Dave K.
    • November 1, 1999
    • 952
    I like to use my jumper as a 12 vlt power source to perform 12 volt DC circuit testing. I use the cigarette lighter receptacles and plug a male connector into the receptable connected to two leads (+, -) that I attach to the component to be tested. Now I am not getting any voltage fom the receptacles but I am getting 12 volt at the large clamp leads. Are these receptacles fused o coul they both be bad?
    Dave K.
  • Mark E.
    • April 1, 1993
    • 4609
    Re: Diehard 1150 12 volt battery jumper
    I'm not clear what you're describing.
    You have a two wire jumper cable with a cigarette lighter adapter on one end and separate clamps on the two wires on the other end?
    It's plugged into the car's cigarette lighter with the other end clamped to a "component". No voltage from the cigarette lighter, but voltage from the component? Is that right?
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Guy F.
      • March 1, 2001
      • 318
      Dave is using one of these as a 12VDC power source:
      It sounds like he is inserting a male 2 wire plug into the female 12VDC outlet, and now the outlet is dead. However, the jumper clamps still have power.
      Guy
      '75 Convertible L-82/M-21 Silver/Silver L
      '73 Coupe L-82/M-20 Med Blue/Black L
      '23 HTC, 3LT, Elkhart Lake Blue/Jet Black red stitched, Z51 with mag ride,
      FEL, 70th wheels, carbon flash roof, nacelles, mirrors, spoiler, full length stripes,
      edge red calipers plus other goodies
      • Dave K.
        • November 1, 1999
        • 952
        correct as shown
        • Mark E.
          • April 1, 1993
          • 4609
          Got it. Wish I could help.
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • Guy F.
            • March 1, 2001
            • 318
            The owners manual says that it has a fuse on the 12VDC circuit. See page 9.
            Guy
            • John D.
              • December 1, 1979
              • 5507
              For testing the old fuel injections chokes etc I use a AC/DC converter. I can dial in the voltage and the amps. Works perfect.
              I use it for testing the solenoids also. I think you would like this Dave. If so I will get you the info on it. John
