Plating question for gas cap on 72 - NCRS Discussion Boards
    • 6950
    What was the plating on the gas cap for the 72. Thanks Ed
    • 43259
    Re: Plating question for gas cap on 72
    Edward------
    Zinc plated.
      • 11679
      Per JG:
      "The large diameter gas cap is dull cadmium or zinc and has SMC for Stant Manufacturing Company in circular stylized script on the underside of the cap. (See Fig. E16.5) The gasket material is black rubber."
      We've been looking for years to see if they were gold like the service replacements.
      IF (and I say IF) they were dichromate (gold), it was a VERY thin wash which doesn't show up on cars 48 years later. Most replating you have done makes the gold very bright and obvious, so it will not appear as they did originally.
        • 43259
        Per JG:
        Patrick-------
        I was incorrect. The original 1972 fuel cap DID NOT have the chromate overplate. However, I believe the chromate overplate was added sometime before the cap went out of PRODUCTION use at the end of 1974.
        It is VERY easy to remove the overplate from SERVICE caps. Just immerse the cap in a weak acid solution like vinegar or citric acid.
        I'll correct my above post.
        • Richard F.
          • September 30, 1981
          • 498
          My original 1974 Corvette Nov. 1973 build has a pale chromate finish gas cap, was that way when I took delivery.
            • 6950
            Thanks everyone, is there anyone that will do something this small.
            • Bob D.
              NCRS Shipping Data Report Manager
              • April 30, 1996
              • 793
              Ed
              I can help with a small job. Send me a PM
              Bob
