pillar post weatherstrip - NCRS Discussion Boards
  • Francais D.
    • October 8, 2016
    • 94
    i have a 69 coupe august build. I am replacing pillar post weather strip; i see some with the lower part attached and then i see some with only the upper portion, my originals are broken right at this point are these one piece or two .Also unrelated to this i am looking for left center bracket #3918519 . This bracket has two bolts thru firewall holds the grill between hood and wiper door. I do not know how to change icon, is was supposed to be 68 69.
  • Mike E.
    • February 28, 1975
    • 5153
    Re: pillar post weatherstrip
    Could you please use punctuation i have a very difficult time reading your post and the easier a post is to read the more inclined some people are to try and help out if you have a technical question if you have a specific part need it was helpful that you included a part number indicating the specific issue you have was also a good idea just a few suggestions for you to consider
