I recently put my re-built LT1 in my Corvette.  I was able to get it started for the initial break in and I did get it started, but it was not immediate.  I ran it for 1/2 hour per the engine shop. When it was running, it was running pretty smooth.
I am trying to run it again and I can't get it started this time. I got one blast of back-fire through the carb, so I know it has some spark. As a simple test, pretty much in the dark so i could see it, I separated the coil wire to the cap to allow the spark to make the jump from the wire to the cap. The spark seemed very weak and possibly it was not firing on a regular basis. I do have weak spark.
Are there any troubleshooting steps any one can help with?
Would the coil be the problem? Is there any way to check the coil for proper output?
I know the T.I. module could be bad. Is there any way to test that before deciding to send that out for repair?
Any other troubleshooting ideas would be appreciated.
Jim
Jim
