leaking timing chain cover 1965 327 - NCRS Discussion Boards
  • Bruce W.
    • June 30, 1997
    • 358
    Hey Guys,
    Question can the seal that the harmonic balancer goes thru be replaced with out taking off the timing chain cover.
    thanks.
    Bruce
  • Paul D.
    • September 30, 1996
    • 491
    Re: leaking timing chain cover 1965 327
    Yes, but be prepared for this job. You should have a proper balancer puller on hand as well as a balancer repair sleeve in case yours has a wear groove cut in it. A new seal goes without saying, however I will remind you to put oil on the rubber part of the seal and where it rides on the balancer. Some like to put some sealer around the outer part of the seal where it fits into the timing cover, but I have found that the paint on the seal does a pretty good job of sealing. Since I have limited experience with the older small blocks, does your 327 have a balancer retaining bolt? Some older, non HP small blocks do not and may not have a threaded hole in the crank. If not, others will need to advise as to how to reinstall the balancer. The tool I have threads into the center hole to pull the balancer back on. Also, be prepared to remove some radiator shrouding to allow space for removing the balancer. Chip.
    • Jim L.
      • September 30, 1979
      • 1808
      Something else to consider is the possibility of distorting the timing cover by the force of driving the new seal in place.
      Every time I've changed the front seal, I've had the timing cover on my bench and have backed up the seal area of the cover with a block of wood. This eliminates any possibility of bending/warping the cover.
      I'll admit I've never tried changing the seal with the cover on the engine. But I can envision the potential for damage if the force needed to drive the seal home is high enough.
      Jim
        • 43219
        Jim
        Jim------
        I agree. I do not see how the seal could be removed, let alone installed, without somehow distorting the timing cover if the cover is mounted on the engine. Distorting the cover virtually guarantees a subsequent leak.
        • Joseph L.
          • July 26, 2012
          • 162
          This is not a problem and it is easy! No hammering.
          Joe
          • Mark E.
            • April 1, 1993
            • 4536
            Super! Thanks for sharing Joe. Did you invent this process?
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
            • Bruce W.
              • June 30, 1997
              • 358
              Joe, i think you are saying that I can change the seal with out taking off the cover right?
              Bruce
              • Paul D.
                • 491
                Excellent presentation! Thanks for sharing!
                • Bill M.
                  • 1322
                  i have used a piece of brass pipe roughly the diameter of the seal slather the seal in oil or grease. put the seal into the cover by hand and the push it in with the brass pipe and lightly tap it with a hammer if needed.
                  • Rich G.
                    • August 31, 2002
                    • 1397
                      • 43219
                      Joe
                      Joe------
                      I cannot view this file as I do not have MS Office. Can you post it in some other format?
                      • Dan B.
                        • July 13, 2011
                        • 545
                        Joe------
                        Here you go. Nice write up from Joe's Garage.
                        Interesting idea!
