Carter AFB replacement - NCRS Discussion Boards
  • Roger H.
    • September 27, 2020
    • 90
    My 1965 with 327-300 still has the original carburetor. It has been rebuilt, but it might be time for a change. Has anyone found a suitable replacement for the AFB that will still accept the original air cleaner?
  • Mark E.
    • April 1, 1993
    • 4600
    Re: Carter AFB replacement
    Isn't the new Eldelbrock carburetor just a rebranded AFB design from 60 years ago? Get one with a detached choke and check the fuel line connection.
    With that said, why is it "time for a change" for the original? It's designed for your engine and if rebuilt properly will probably perform the best.
    I do understand the fun with tinkering with different carburetors (I have three for my Corvette), and having a spare can be handy at times.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Roger H.
      • 90
      Thanks for the info Mark. I'd like to use the original. It might just be time for another rebuild.
      • Chris D.
        • November 1, 2002
        • 198
        • Roger H.
          • 90
          Thank you Chris. I'm getting lots of good advice here. My car is mostly original under the hood. I'd like to keep it that way.
          • Christopher R.
            • March 31, 1975
            • 1599
            The top of your existing stock AFB carburetor - the air horn - will fit onto a new Edelbrock Performer carburetor. You can buy a new Edelbrock and swap air horns. That way you get a new carburetor, and all your stock '65 stuff will bolt up. Linkage, choke, gasoline line, and air filter.
            Of course, you may not need a new carburetor. But if your heart is set on a new one. This'll work.
            • Roger H.
              • 90
              Mr. Ritchie, Thanks for the input. I hadn't considered that option. If I can't get the original carb working to my satisfaction, I will try replacing it and swapping parts.
              • Mark E.
                • April 1, 1993
                • 4600
                What a great option for cars with an AFB carburetor.
                It's curious Eldelbrock chose the AFB for their current line of carburetors. The design is from the 50s. From a street performance perspective, the Q-Jet is a better architecture. Yes, it's spread bore design is limited to mostly GM cars but that's a large market.
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
                • Timothy B.
                  • April 30, 1983
                  • 5196
                  Roger,
                  The AFB is a very good carburetor and well worth saving. Get a pro to bush the throttle bores (if needed) and overhaul it.
