C2 Fuel Filler Boot Replacement - NCRS Discussion Boards
  • David M.
    • December 11, 2011
    • 48
    I need to replace the fuel filler boot without dropping the tank. Is there a secret to doing it correctly?
  • Joe R.
    • July 31, 1976
    • 4552
    Re: C2 Fuel Filler Boot Replacement
    Nothing to it! A new one will stretch over the end easily. Don't forget the drain nipple and hose.
    JR
    • Owen L.
      • September 30, 1991
      • 893
      I changed out the one on my '72 recently. The hardest part was getting the old one off as the rubber had gotten quite stiff and unyielding; I ended up resorting to using a box cutter to slice the old one off. Make sure you save the old drain nipple from the boot for use in the new one.
      • David M.
        • December 11, 2011
        • 48
        JR, do I need to get a new nipple and hose as well as the boot or can I use the present one?
        • Joe R.
          • July 31, 1976
          • 4552
          David, the nipples and hoses are available but the old ones should be fine.
          JR
          PS. don't try to pull the hose out as it is tied to the bumper on the lower end. You can remove the tie before you start and it will free up the hose when removing the boot.
          • Bill M.
            • 1329
            The worst part of this job is getting the renforcing spring inside the new hose. Soak the hose in hot water for a while and then twist it in.
              • 6958
