C3 -- Have you seen this? - NCRS Discussion Boards
  • David C.
    • June 30, 2006
    • 126
    I have this curious cut on the cowl frame fiberglass on my '73.
    I'm not sure if it's simply some sloppy work on the body build at the assembly plant, or someone did this afterwards (a possible body work repair attempt?). Am really just curious if anyone has seen this on another car.
  • Mark E.
    • April 1, 1993
    • 4611
    Re: C3 -- Have you seen this?
    I haven't seen this on another car. Any evidence of other bodywork?
    The good news is this is easy to repair.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Jimmy P.
      • June 24, 2014
      • 1696
      Hi Dave,
      Interesting. I took a look at my 73 cowl and did notice a slight notch along the edge on the driver side, like they were starting to dig in too far but stopped. Not near the center though. It does have a sharp edge. Not as pronounced as yours. I'm thinking probably sloppy work at the factory. What body work would be needed in that location? I notice that piece of thin material under the center section.... what is that? Metal? I can't say that I notice it on my car.
      Jimmy
      1973 Convertible
      L48,M20,N40
      Mille Miglia Red/Oxblood
      • Robert G.
        • May 17, 2019
        • 68
        I will check mine and get back to you.
        • Keith K.
          • January 23, 2008
          • 510
          My 74 has this cut as well - it is on both sides but more pronounced on the driver side - not as deep as yours. I have seen it on other cars as well.
          • Lawrence M.
            • February 1, 1995
            • 404
            74 Coupe I ordered in December 73, took delivery early March 74 Vin#18168. Photo taken Memorial Day 74. It appears the factory had different ways of t******* the underlying fiberglass. Probably depending on who was working that operation on any particular day.
            Larry
            2002 Z51 Convertible
            1969 L46 Convertible
            • John S.
              • June 15, 2015
              • 508
              I’ve also noticed similar cuts on a few different C3’s to varying degrees. Here’s a couple shots of my ‘73, not too bad but still evidence of some cutting, believed to be factory.
              In addition to the photos, I did find this reference in my trusty AIM. It appears there may have been an additional section of the FG hood surround that was cut away after the bond was made to the top of the firewall. Looks like it was attached on the ends and three sections in the center span, perhaps we are seeing remnants of that procedure. Not sure if this pertains to earlier/later C3’s, perhaps others will chime in.
              1973 L82 M21 4 Speed, very original and well documented driver/survivor
              NW Chapter Member, 2016 Bend Regional Top Flight
              73/74 TIM&JG 3rd Edition Revision Team Member
              • Jimmy P.
                • June 24, 2014
                • 1696
                Hi John,
                Yeah, I noticed that in the AIM.. Could you only imagine, being the guy on the line that drew the short straw for that duty?
                Cutting away that area with a jigsaw all day long ugh! No wonder we're seeing what we see here...
                Jimmy
                1973 Convertible
                L48,M20,N40
                • Robert Y.
                  • January 11, 2020
                  • 25
                  Dave, I have a 73 with the 454 engine and looking at my cowl, it looks similar to yours. It looks on mine as if someone took a gallon sized bucket and just poured it in there. The man I bought my car from bought it new and told me nobody had ever done any work on it other than the repaint. I'm sure they wouldn't have done this.
                  • David C.
                    • June 30, 2006
                    • 126
                    • John S.
                      • June 15, 2015
                      • 508
                      • Mark E.
                        • April 1, 1993
                        • 4611
                        Well, I learned again that just because I haven't seen it doesn't mean it doesn't happen.
                        What an appalling example of GM workmanship. If I saw this upon delivery, I would have asked for it to be repaired.
                        Mark Edmondson
                        Dallas, Texas
                        Texas Chapter
                        • Mark F.
                          • July 31, 1998
                          • 1610
                          So, the burning question I have had looking at all of this is:
                          Why did this have to be done?
                          thx,
                          Mark
                          • John S.
                            • June 15, 2015
                            • 508
                            • Mark E.
                              • April 1, 1993
                              • 4611
                              Originally posted by John Sigmund (61302)
                              LOL, apparently the word “t r i m m i n g” is being censored !!
                              I didn't know it was a naughty word until I visited this forum.
                              Mark Edmondson
                              Dallas, Texas
                              Texas Chapter
