1966 Engine Detailing - NCRS Discussion Boards
  • Tim T.
    • March 1, 1982
    • 70
    As my project continues I got photos from shop and a couple items popped up immediately. Would like to verify if i got this right. On a 66 327/300hp oil filler tube should be black not orange? Cap also black not chrome? The water outlet should be aluminum not orange? Thanks
    • 43209
    Re: 1966 Engine Detailing
    Tim------
    The oil filler tube was painted semi-gloss black (it was installed at St. Louis so it was not painted with the engine). The oil filler cap was black but it was not painted. It was a black electroplated finish. The thermostat housing was painted with the engine and, thus, was orange. Engines with aluminum manifolds had natural aluminum or aluminum painted thermostat housings.
    • Tim T.
      • March 1, 1982
      • 70
      Thanks Joe,
      Wanted to make sure I was correct on these items. They painted oil filler orange w chrome cap and left thermostat housing natural. So I'll have them fix these minor issues. Appreciate the reply. Tim
      • Larry E.
        • 1673
        Another question for Joe>This comes up once in a while also>
        Is there or is there not a bracket that holds the PCV Hose that connects the Carb to the PCV Valve? Pictures Below>
        Thanks Larry
        Larry
        LT1 in a 1LE -- One of 134
