on a 65 SB convertible dash harness what does the screw look like that goes to the ground wire behind the radio? Also on the heater cable fan switch I have a "extra" single terminal with a tab that sticks out with no wire to connect too. I don't see it in the AIM wiring diagram and I have all three speeds of the heater blower fan.
two 65 dash wiring questions
Re: two 65 dash wiring questions
Keith, the extra lug is for rear coupe vent, if used, not a convertible, not sure on the screw.
Dan1964 Red FI Coupe, DUNTOV '09
Drove the 64 over 5000 miles to three Regionals and the San Jose National, one dust storm and 40 lbs of bugs!- Top
Keith,on a 65 SB convertible dash harness what does the screw look like that goes to the ground wire behind the radio? Also on the heater cable fan switch I have a "extra" single terminal with a tab that sticks out with no wire to connect too. I don't see it in the AIM wiring diagram and I have all three speeds of the heater blower fan.
Is his the ground wire you are referring to? Sorry the photo always rotates when it is copied from my iphone.
IMG_8579.jpg- Top
