1975 L-48, 4 speed with A/C Heater hoses? - NCRS Discussion Boards
  • Lynn S.
    • May 5, 2016
    • 105
    The 1975-77 NCRS technical manual and Judging guide page 77, Heater Hoses, reads ... the most common designs have 3 or 4 narrow ribs along their length that is a code to indicate the manufacturer. These ribs are narrower than those on current service replacements. A/C cars have molded bends at the heater core and intake manifold end. On Non-A/C cars without an expansion tank, ...
    Checking with several vendors who state in their description "reproduction quality or same as original" for the correct hose replacement, I am repeatedly told that '68 - '82 cars with A/C in their experience had smooth hoses due to the additional manufacturing process to mold in the bends at each end. Their experience had the ribbed hoses on Non-A/C cars '68 - '82.
    I cannot find ribbed hoses with molded ends.
    Please advise. Thanks
    Lynn Skipper 62393
    1995 LT-1 Polo Green conv. w/ Beige/Beige, Chapter Top Flight
    2018 LT-1 GS conv w/ Kalahari/Black, Heritage pkg, 2LE, 8sp w/ paddles
    1975 L-48 Steel Blue conv, w/ Med Saddle/Med Saddle, 4 spd, C-60 current project.
    • 6956
    Re: 1975 L-48, 4 speed with A/C Heater hoses?
    Lynn, There does not seem to be any Corvette venders interested in making these hoses, about 10 years ago when I restored my 72 and I was looking myself for the hoses. judging the hoses it only 1 point deduct.
    • Tom R.
      • June 30, 1993
      • 4102
      Lynn
      We are in the midst of the 75-77 revision and, ironically in the cooling system section. I'm attaching a draft of the revision for heater hoses and we are in process of confirming part numbers and configuration. You'll find that A/C were molded and included, perhaps not ribs but grooves. Also, introduced in 74 is the water-shut off valve but we find conflicts with its use in 75, whether included with A/C or non A/C applications. After 75, all years included the water shut-off valve and the same hoses were used. So take a look at this. Perhaps you can help us "tweak" the details as configured in 75.
      1975-77 _heater hoses_23Oct20.pdf
      Tom Russo
      78 SA NCRS 5 Star Bowtie
      78 Pace Car L82 M21
      00 MY/TR/Conv
      • Larry M.
        • January 1, 1992
        • 2701
        Closest I have found are from DR REBUILD. Assuming he opens his store back up, you should probably get these for your car.
        Larry
          • 6956
          Larry years ago Doc had one NOS 3/4 hose, @120.00 I believe.i ended up buying the molded hoses from him. No groves or or codes stamped on them. I like some of the Doc parts, I am to waiting to place an order with him, last I heard it was going to be beginning of next year.
          • Lynn S.
            • May 5, 2016
            • 105
            Thanks Larry for your input and advice. Mine is not a Survivor car. Just one I am trying to restore as correctly as possible.
            Lynn Skipper 62393
            • Lynn S.
              • May 5, 2016
              • 105
              Thanks for your help and the attachment. My car was one of the proverbial basket case cars. Not a fully assembled survivor. So I'm just trying to restore it as correctly as possible. Hope to see you in Lakeland next February.
              Lynn Skipper 62393
              • Lynn S.
                • May 5, 2016
                • 105
                Thanks again Larry for your reply.
                Lynn Skipper 62393
                • Lynn S.
                  • May 5, 2016
                  • 105
                  Ed, thanks for your reply. I will probably go your same route and take the hit on originality.
                  Lynn Skipper 62393
                  • Jeffrey S.
                    • May 31, 1988
                    • 1899
                    Lynn,
                    Attached are hoses with the molded ends and grooves/ribs. I purchased these from the vendor in the second photo at Carlisle.
                    Jeff
                      • 6956
                      • Lynn S.
                        • May 5, 2016
                        • 105
                        Thank you very much Mr Salzburg for the info on the hoses. I will be calling them Monday morning. Wish me luck.
                        Lynnf
                        Lynn Skipper 62393
                        • Jeffrey S.
                          • May 31, 1988
                          • 1899
                          Jeff I’ve seen that vender in Carlisle, that’s the first time I have seen a hose with grooves do you remember if both hoses has the grooves or was it just the 3/4 hose? Thanks Ed, hope there still in business.
                          Both hoses had the same grooves. They also had the GM logo- lacquer thinner works great!
                          Jeff
                          • Jeffrey S.
                            • May 31, 1988
                            • 1899
                            Lynnf
                            OK- good luck!
                            Jeff
                              • 43279
                              All------
                              The number of ribs or grooves on the hoses was a code which denoted the hose manufacturer. I don't know that they were required if the manufacturer was otherwise identified by a code printed on the hose.
