Looking for advice re: the front carrier bracket for a 65 differential. My mechanic, despite having the 1963 service manual for guidance, failed to put a 1/2 inch piece of wood between the carrier and floor and proceeded to remove the nuts and washers from BOTH front through bolts and then tried to remove the rearmost bolt (the one you're supposed to only loosen). As predicted in the service manual, I think the carrier has twisted upward and now the rearmost bolt, which has been pulled out of the carrier bracket on one side and is protruding on the opposite side in contact with the jack well floor, can't be re-installed nor removed.
I'm wondering of the source of torsion which causes the carrier to twist upward is the transverse spring, installed to the trailing arms, and if so, whether disconnecting the spring from the trailing arms would allow the carrier to be returned to its position on the carrier bracket and the rearmost bolt to be re-installed (pushed through) the other side carrier bracket hole, prior to following the service manual instructions correctly (ie: merely loosening the rearmost bolt, removing the front bolt and rotating the carrier bracket downward to permit access to change the pinion seal).
Can anyone advise?
Grant
Can anyone advise?
Grant
