Cycle of building 62 engine - NCRS Discussion Boards
  • Roger B.
    • June 30, 1991
    • 82
    What functions at Saginaw Mi
    what functions at Flint Mi
    what functions at St. Louis
    What ha
    • 43295
    Re: Cycle of building 62 engine
    What ha
    Roger------
    Saginaw:
    casting of cylinder heads, engine block, waterpump
    Flint:
    Machining of cylinder heads, block, camshaft, connecting rods, crankshaft, waterpump, intake manifold, exhaust manifolds
    Assembly of all of the above into complete engine assembly adding all valve train parts, timing set, pistons, bearings, oil pan, timing cover, harmonic balancer, valve covers, spark plugs, distributor, flywheel, clutch/pressure plate (if required), bellhousing (if required), release bearing (if required), clutch fork (if required);
    St. Louis:
    adding all engine peripherals including carburetor or fi, fuel pump, alternator, starter, pulleys, belts, brackets, engine mounts, RFI shielding, air cleaner, fan, fan clutch, spark plug wires, coil
    • Roger B.
      • June 30, 1991
      • 82
      Roger------
      Saginaw:
      Flint:
      St. Louis:
      when did the serial number stamping accure and the horse power codes stamped
        • 43295
        Roger-----
        The engine code (the sequence beginning with "F") was stamped at Flint Engine. The vehicle VIN derivative was stamped at St. Louis.
        • Roger B.
          • June 30, 1991
          • 82
          Thanks Joe for the history lesson
          Roger
