1968 435HP Corvette with Air Conditioning - Available? - NCRS Discussion Boards
  • Kevin M.
    Infrequent User
    • July 31, 1991
    • 2
    Last week I purchased a 1968 Big Block Corvette Coupe (body build Feb 16 1968) that was listed for sale by a farmer in Iowa who owned it since 1982. The price was right whether a big block or small block so I purchased it. The farmer stated that all he did was drive it very rarely and do a little maintenance on it since 1982. However, he decided to sell it when the tires started falling apart because they were completely dry rotted from sitting. I was able to verify that he indeed was the owner of the car since 1982 with an original registration receipt. Its looks to be a very original corvette showing 43,261 miles (could be 143,000 but the interior seems to be in to good of condition). It does need total restoration from sitting on concrete floor and being banged and scratched. It is a Red on Red with the Original Interior but was repainted once at some point.
    The farmer purchased the car from a small local car dealership who had installed a small block after it was traded in by another local guy who blew up the BB. Several things intrigued me about the car, It had its original Red interior, showed a 6500RPM tach (dash appears to be untouched), the transmission matches the VIN and has been untouched, the transmission ID tag was still attached #3915031, transistorized Ignition is intact #111296 and is working well, sway bars both measure out to a Big Block, single fuel line, and it has the heavy duty rear U-joint caps. The farmer replaced the gas tank back in the late 90's so the tank sticker is not available. It does not have power brakes but it does have power steering.
    My question to the group is - was factory Air Conditioning an option for the 435HP BB? This Corvette has factory A/C. Could you buy a 1968 435HP with Air conditioning? Currently the compressor and brackets are missing but everything else is there so I wanted to get the groups opinion.
  • Rich G.
    • August 31, 2002
    • 1403
    • James G.
      • August 22, 2018
      • 805
      Re: 1968 435HP Corvette with Air Conditioning - Available?
      As far as I know the only solid lifter engines ever offered with A/C were both Small blocks - the L76 and the LT1 in 1972.
      Also 68's have single fuel lines for all engines.
      James A Groome
      • Chris H.
        • April 1, 2000
        • 837
        AC not available with L71.
        • Brad Hillhouse (37766)
          Kevin - I am doing a survey of 1968 Corvettes equipped with C60 factory air conditioning. There were several running changes that I am trying to document. If you would be interested in sharing your car with me, I would appreciate pictures of engine compartment, interior center gauge stack, trim and vin tag data.
          thank you
          Brad Hillhouse
          bradhillhouse@yahoo.com
            • 43259
            James------
            1968 Corvettes have dual fuel lines for all Q-Jet equipped engines. Only Holley carbed engines have single fuel lines.
            • E S.
              • December 29, 2008
              • 451
              Hi Joe- In1969, I owned an L71 with M40, (had one hell of a passing gear, by the way); but never heard of any year L71 with C60.
              • William H.
                • January 11, 2010
                • 65
                No the highest HP 427 with AC was 400HP
                • Kevin M.
                  Infrequent User
                  • July 31, 1991
                  • 2
                  • James G.
                    • August 22, 2018
                    • 805
                    I stand corrected, thanks
                    James A Groome
                    • David B.
                      • March 1, 1980
                      • 689
                      1968 Corvette C60 option breakdown:
                      The exception letters noted:
                      Coupe --- Convert.
                      AG 269--- AB 412
                      AH 1188-- AC 1,056
                      AM 940--- AL 1,140
                      BB 323---- BA 146
                      BD 3------ BC 2
                      BH 130---- BG 55
                      Last edited by David B.; October 6, 2020, 05:38 AM. Reason: clear between columns lsted
                      • James G.
                        • August 22, 2018
                        • 805
                        Someone could have added all the factory AC components however I would have thought a dealership would just use one of those add on units. The amount of controls and equipment to install AC is just ridiculous, swapping a L71 into an AC car would have been a much less entailed undertaking.
                        Is the distributor date prior to the build date of the car?
                        Was the trans number different for L68's vs L71's?
                        IF trans number is not doff, then a L71 complete engine dist to pan could have been swapped at one time, the engine expiring and the dist pulled to install in the SB so the tach worked.
                        As an aside I owned a 69 L46 in the early 90's, the car was no radio from the factory, built in November of 69 and it had a 6500 redline tach which appeared to have been there forever...not saying it was original just saying it was there in 1991 when I paid 4k for the car.
                        James A Groome
