Re: Question On Removal Of Old(30+Years) Wiper Arms (C2 Corvette)
Success at last. Tried the Freeze-Off and let it penetrate for about 10 minutes. Then tried the Snap-On tool and off they came
both drivers and passenger side. Can I tell you it was the Freeze-Off conclusively>>NO. I had put other types of penetrating oil
several days ago. All I know it worked this time with the Freeze-Off. Never did have to drill through the top of the "cap". Next step
is to run a Dremel with a small wire brush over the spline to clean up and to be sure no burrs are on there. Before installing the
N.O.S. Trico Arms I will put a little white grease in them and also put a couple of drops of Freeze-Off on the car splines to make them
a little smaller. Comments always welcome and thanks to all on the responses. Larry
