396 LH Valve Cover - no depression for Brake Booster? - NCRS Discussion Boards
  • Skip N.
    • June 30, 1980
    • 33
    Just curious to see WHAT this BB Valve Cover is for?? (maybe pass car?)
    - bought it with a group of BBC Parts
    - never seen one without the depression???
    - few 396 BB pics I have show the normal Brake Booster depression
  • Jimmy G.
    • November 1, 1979
    • 977
    Re: 396 LH Valve Cover - no depression for Brake Booster?
    Photo please
    • Keith B.
      • September 15, 2014
      • 1600
      There where over 100 BB valve cover variation for different engine configurations and options
      • Skip N.
        • June 30, 1980
        • 33
        1) not sure IF I uploaded VC pics correctly??? Should be attached?
        2) I have seen a lot of BBC VC in my day ; never saw one without any Brake Booster Indent???
        • Keith B.
          • 1600
          Two things. It’s chrome strike one for a 65 Corvette. And two no clips on the top side for the temp sender wire.
          • Skip N.
            • June 30, 1980
            • 33
            Thanks - forgot about Temp Sender clips
            SO...must be some BBC Pass Car application (or Truck if chrome is stripped)
            • Keith B.
              • 1600
              If the temp sender clips are on the bottom it’s for a 68-70. As they stoped using chrome on pass starting in 71. If no clips I would think it’s a repro
              • James G.
                • August 22, 2018
                • 808
                IT's for 69 Chevelles and full size. 68 IS THE SAME COVER MINUS the temp wire clips because 68's had their alternators on the same side of the engine and the temp wire was part of the alt harness, it draped over to the sender.
                IF the plug wire stand were to be on the other side of the top hole for the valve cover bolt the application would be Nova and Camaro the engine is much closer to the wiper motor on these two models so the wire stand is in front of the last Hole to give more clearance for aforementioned motor.
                here is a link to a research report -
                First-Generation Camaro Research and Restoration Data
