C1 New Springs - Sag height question - NCRS Discussion Boards
+ More Options
Posts
  • Joe P.
    • October 4, 2007
    • 209
    just finished the total rebuild of the front end. Many thanks again to Tom Parson and Aaron O'Brien's posts and replies to my many emails and conversations.
    I finally got it all back together and been driving it, regreased it and rechecked the ride height as indicated in the ST-12, and noticed some sagging. i ordered the deluxe kit from CC with new shocks, new springs, new everything possible. <br />
    i remeasured the ride height and was surprised the seems to be some sagging in the first 200 miles. The spec is 11 +/- 1/2”. i remeasured and now have 10” on the passenger side and 10 1/4”on the driver side.<
    Is this normal ? I read in the ST-12 that shims may be need at the top of the spring.. Is it a direct correlation in that i should add at a 1” space to get back into the specification?
    Any recommendations on where to purchase these spacers?
    Appreciate your input on this.. thanks, Joe
  • Gary C.
    Administrator
    • October 1, 1982
    • 17971
    Re: C1 New Springs - Sag height question
    Joe,
    Body ride height measurements. Hope this helps you.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Joe P.
      • October 4, 2007
      • 209
      Thanks I will take some of these measurements and do a comparison and report back.
      • Joseph L.
        • July 26, 2012
        • 162
        Those points of measurement are the easiest to do. The +/- 1" tolerance also needs to be considered. If in tolerance, and high in the front and low in the back; it will be visually apparent. That condition will show as a droopy rear.
        • Terry D.
          • May 31, 1987
          • 2698
          Did you measure right after completion? You don't say what size tires you are running.
          • Joe P.
            • October 4, 2007
            • 209
            • Gary C.
              Administrator
              • October 1, 1982
              • 17971
              Joe,
              Curious about the height differences. Did you measure before replacing for a base line?
              Were the front springs installed correctly? IIRC there's a ridge on the lower A Arm that blocks the spring end from turning.
              Gary
              NCRS Texas Chapter
              • Joe P.
                • October 4, 2007
                • 209
                Originally posted by Gary Chesnut (5895)
                Joe,
                Gary
                Gary i didn't measure a base line before the dissasembly.
                when i installed the spring i installed them to the same location that i took them off. just on the edge of the drain hole. i didnt notice any ridge. IMG_7846.jpg
                • Gary C.
                  Administrator
                  • October 1, 1982
                  • 17971
                  Joe,
                  You did good reinstalling the spring. Ridge bump visible in your photo.
                  Gary
                  NCRS Texas Chapter
                  • Joe P.
                    • October 4, 2007
                    • 209
                    Joe,
                    Gary
                    Gary I measured 27 1/2' from the ground to the center of the headlight, on the rear fender well I measure 29 3/4"
                    • Gary C.
                      Administrator
                      • October 1, 1982
                      • 17971
                      Joe,
                      Please post a level side view photo.
                      Gary
                      NCRS Texas Chapter
                      • Stephen L.
                        • May 31, 1984
                        • 3163
                        Why not use the concept for ride height as used on C2's.
                        Front: 1) Measure from the bottom surface of the spindle to the ground
                        2) Measure from the bottom of the lower "A" frame mounting bolt to ground
                        3) Subtract these dimensions from each other.
                        This procedure will eliminate discrepancies in tire height, inflation, body condition, etc.
                        Rear: 1) Measure distance vertically between the frame bottom surface and the top surface of the rear end housing.
                        Again, this eliminates discrepancies in tire size etc.
                        You will need to survey C1 owners to obtain an average of what those dimensions should be....... unless this information exists in GM documentation.
                        This can eliminate differences due to body mount condition, poor body repairs etc.
                        Hope this might help the C1 owners
                        • Gary C.
                          Administrator
                          • October 1, 1982
                          • 17971
                          Stephen,
                          Great idea. Unfortunately, there are not any C1 factory dimensions like they are for C2's.
                          Only ride height to ground are from AMA specs, previously attached with mark ups and the '57 AIM - see attachment.
                          Gary
                          NCRS Texas Chapter
                          • Stephen L.
                            • May 31, 1984
                            • 3163
                            Gary,
                            I realize that there are no specs like there are for C2's. I did suggest that a SURVEY of C1 owners might yield a dimension average that could be refered to..........using the C2 technique.
                            Steve
                            • Gary C.
                              Administrator
                              • October 1, 1982
                              • 17971
                              Stephen,
                              Sorry, didn't explain very well. C1's have a tendency to squat, meaning the rear springs sag. Which means getting comparative measurements, won't give you good data. That's one of the reasons I asked Joe to post a level side photo.
                              Data points from my previous posts:
                              - post #2 - 13.2 inches from ground to center of rear axle
                              - post #14 - 11 inches frame to ground
                              Gary
                              p.s. measurements from ground depend on the type of tires that are on the car - factory to ground measurements are for OEM tire size
                              NCRS Texas Chapter
