Mid-Year Wiper Arm Installation(Mine is a 66) - NCRS Discussion Boards
  • Larry E.
    • 1677
    Need some tips on the above installation; never have done this before. I do have a snap-on A192 wiper arm
    removal tool. You-Tube has a nice program on it's use. One question that comes to mind is it better to install
    the N.O.S. Trico Original Wiper Arms WITH OR WITHOUT THE HOLDER/BLADES ATTACHED? The way it looks to
    me is it would be easier W/O but by doing this it may be harder to install the arms on the proper position on
    the splines. Correct?? I assume a little of the white grease would be OK on the splines. Any tips are welcomed>Thanks in Advance>>Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Stephen L.
    • May 31, 1984
    • 3156
    Re: Mid-Year Wiper Arm Installation(Mine is a 66)
    The wipers are easier to install with the blades in place. The left blade should be close, but not touching the windshield trim. The right blade should be above the left..... When setting the final angle, wet the windshield while running the wipers to see where they "park" and adjust accordingly. The arms have an adjusting screw for fine tuning. Before you start, I'd set those adjusting screws at midway, so you have some +/- movement.
    Small amount of grease on the splines is good.
    • Bill S.
      • April 30, 2002
      • 154
      Do you have a link to the YouTube video on the Snap-on A192? Thank you
      Bill Strobel
      Owner Independent Towing
      Fayetteville, NC
      1979 Corvette White/Red L-82 4 spd
      Only 4,200 miles
      Do It Right or Don't Do It At All
      • Larry E.
        • 1677
        Bill>Sure do>>https://www.youtube.com/watch?v=eKvbtxGiI_w
        Larry
