C3 "rubber" bumper - NCRS Discussion Boards
C3 "rubber" bumper
  • Frank D.
    • December 27, 2007
    • 2703
    C3 "rubber" bumper
    A friend has asked me to help him touch up his later C3 bumper; I'm willing to try but not 100% sure how to proceed....is the process the same as for metal/fiberglass? Level out the ding with filler, touch up with base coat and wet sand (can you do that on rubber?) and then clear ?
  • James G.
    • August 22, 2018
    • 800
    Re: C3 "rubber" bumper
    You need to use a spreadable flexible material to repair the depressions... otherwise if flexed it can pop the filler.
    For major building or repair I use 3M 2 part automix flexible repair -
    I prime with Spies Hecker flexible primer... and then base and clear.
    I still put flex agent in my clear coat even though I have been told it is not necessarily required any longer.
    James A Groome
    • Frank D.
      • December 27, 2007
      • 2703
      Perfect - thanks!
      • James G.
        • August 22, 2018
        • 800
        The Spies Primer is essential -you can literally spray a beach ball with it and then deflate the ball a week or two later and the primer remains... even many years later. I saw one of the beach balls sprayed by the Spies rep a few years after the demo and the primer was still fully adhered this was 6-7 years ago I have not painted flexible parts without using it since. Your jobber will be able to point you in the right direction.
        I added 1/2 an inch of material to the end of the bumper and did deformation tests - bending the edge to significantly greater than a 45 degree angle in relation to the added material, then primed with the above and base clear.
        James A Groome
        • Frank D.
          • December 27, 2007
          • 2703
          That's pretty amazing and nice work too!
          Not sure I'm the guy for this job as a "first timer" though - my pal may need to get a pro...
          • Joseph S.
            National Judging Chairman
            • March 1, 1985
            • 867
            Frank, Isn't a friends car the perfect car to practice on?
            • Frank D.
              • December 27, 2007
              • 2703
              Yeah, but I'd like to keep him as a friend!
