Uniroyal Tigerpaw 2 whitewall turning yellow/brown - NCRS Discussion Boards
    • 6950
    Re: Uniroyal Tigerpaw 2 whitewall turning yellow/brown
    What are you guys using to clean your white wall westlys bleach white use to be the best, but is no more, I hate when they change formulas.
      • 11679
      Lacquer thinner will work if you're careful. Worked great on the Firestone 500s I detailed just before Bloomington a few weeks ago.
      Tried it on the new BFGs; lasted less than a week.
      • Frank D.
        • December 27, 2007
        • 2703
        #18
        I just used Simple Green (which is what some manufacturers like Diamondback recommend), except on the faulty Uniroyals which required a 600 grit foam sanding block and even that only lasted a week or two.
