Harmonic Balancer? 66 327/350 L79 - NCRS Discussion Boards
  • Rich G.
    • August 31, 2002
    • 1403
    EDIT EDIT SEE BELOW.
    I heard a noise I thought was the water pump failing although no leak. In the process of taking it off I ran the motor with the belt and pulley off and heard no noise. The car has no options, so the alternator is the only other rotating component.
    I replaced the water pump and I hear the same noise, squeak/metallic rattle. I repeated the last test by simply removing the fan/alternator belt and starting the engine except this time the pulley is on but not rotating.
    Now the sound is like a dinner bell. The sound you would hear when banking on a stationary pulley with a hammer. So it appears the balancer is wobbling and intermittently tapping on the water pump pulley. Does this indicate a failed balancer or something more serious?
    EDIT EDIT EDIT
    Problem was/is the damper was loose. Tightened the bolt. We shall see how long that lasts.
    Rich
    ps; Now I know how to change a water pump!
