C2 St. Louis Factory Assembly Line Question - NCRS Discussion Boards
  • Gary C.
    Administrator
    • October 1, 1982
    • 17587
    Anyone know the time it took from start to finish to produce a 1965 Corvette?
    Am specially interested in the length of time from chassis build to completion.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • December 31, 1992
    • 15629
    Re: C2 St. Louis Factory Assembly Line Question
    John Hinckley can give a more accurate answer than me, but based on my experience (getting hazier with time) as a Pontiac production engineer...St. Louis was running two shifts at that time, and it would have probably taken the body from building the bird cage to final inspection more than one shift to be ready to drop on the chassis, depending on how much rework, if any, was required by the paint shop for it to pass inspection.The final assembly operation - from the time the frame was set on the fixture upside down to mount the suspension components to the time it was driven to the shipping lot (assuming no rework required) was certainly less than one shift - like a couple of hours.Duke
    • Loren L.
      • April 30, 1976
      • 4104
      You need a H_ of a lot more information than you provide - there was a national strike in the Fall of 1964, complicated by a localized strike in St Louis at the assembly plant.
      • Gary C.
        Administrator
        • October 1, 1982
        • 17587
        Mr. Lundberg,
        Am asking about generically, what's the amount of time/number of days on an average that it took to produce a '65 during spring of '65.
        Thank you,
        Gary
        NCRS Texas Chapter
        • Harry S.
          • July 31, 2002
          • 5268
          I'm sure Snake will chime in soon!
            • November 30, 1997
            Snake reporting in!
            I'd have to dig out my plant layout drawings, which I put away the last time we moved 20 years ago, to do an accurate jobs-in-system count. However, as a rough count, the total system at Corvette was less than 200 units, and producing 112 units per day on 2 shifts, it would have taken about a day and a quarter to go through the system from the Body Shop to the Shipping Gate. If I can find my plant layout drawings, I'll break it down in more detail and post back.
            • Gary J.
              • March 31, 1980
              • 1230
              John, glad to see you reporting in.
              • Mark F.
                • July 31, 1998
                • 1483
                Snake reporting in!
                Hi John,
                Is the link below the St. L. Plant layout you were referring to?
                St Louis Corvette Plant layout from 2011 NCRS National Convention.pdf
                I extracted it from an NCRS National Convention Presentation you did July 20, 2011 on the 1963-1967 Corvette Assembly Process...thx, Mark
                thx,
                Mark
                • Gary C.
                  Administrator
                  • October 1, 1982
                  • 17587
                  Mark,
                  Good find! Appreciate your posting. Thanks,
                  Gary
                  NCRS Texas Chapter
                  • Mark F.
                    • July 31, 1998
                    • 1483
                    Good deal, Gary...thx
                    FYI to all your readers of this post, Rich Mozetta's STICKY POST of NCRS Restoration Documents has links to 3 documents John wrote (and presented) on the C2 Assembly Process. All well-worth a full read - very informative!
                    C2 Assembly Process C2 C2 Assembly Process Part 1 - John Hinkley.pdf
                    C2 Assembly Process C2 C2 Assembly Process Part 2
                    C2 Assembly Process C2 C2 Assembly Process Part 3
                    thx,
                    Mark
                    • Gary C.
                      Administrator
                      • October 1, 1982
                      • 17587
                      Duke,
                      Thank you for sharing your experience @ Pontiac.
                      Gary
                      NCRS Texas Chapter
                      • Gary C.
                        Administrator
                        • October 1, 1982
                        • 17587
                        Mark, Part 2 & Part 3 are moved - get new links from: https://www.ncrsmac.org/Tech-Library Gary....
                        NCRS Texas Chapter
                          • November 30, 1997
                          Originally posted by Mark Francis (30800)
                          Hi John,
                          [ATTACH]101292[/ATTACH]
                          Mark -
                          That one gives an overall layout, but without any detail or scale; if I can find it, I have the detail process layouts with workstation and product measurements. May take a while to find them.
                          • Mark F.
                            • July 31, 1998
                            • 1483
                            John, Understood and thanks much - that would really be cool if you can dig them up!
                            thx,
                            Mark
                            • Roy S.
                              Past National Judging Chairman
                              • July 31, 1979
                              • 1023
                              Interesting John says a day and a quarter 30 hrs. The C6 was 36 hrs. Appears it has not changed much in the last 40 plus years.
