All,
I have had a slight miss at low rpm, while cruising, for a while. I finally got around to ordering and installing a new breaker plate ground wire as mentioned in some of the older threads. I recommend anyone who has a similar issue to do this. The old wire, was very stiff, while the new is very flexible. It did come with two ends that had tabs to be screwed down. I had to take one off and use the bare wire at one terminal.
George
George
