My friend is restoring a 71 vette.  He purchased it with a crate engine installed.  The core support appears original and is for a 454.  However, that can easily be replace along with other indicators of engine size such as the console plate, etc.  Are there any indicators that are not as easily changed that would provide an indication if the car was originally a small block or big block?  I appreciate the help!
					Indicators of a 1971 Big Block Car
Re: Indicators of a 1971 Big Block Car
Does it have a rear sway bar? What is the rear end code? What is the diameter of the front sway bar?- Top
Aren't big block half shafts shot peened?Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
Some indicators are suspension components such as shocks and their tags, front coil springs and their tags, the size of the front swaybar and also if they have rear swaybars. Also look for the heavy duty caps on the inboard part of the axle half shaft connecting to the outboard part of the rear end All big blocks have, automatic big and small block along with small block high-performance and all automatics are shot permed with number 31 number 31 shot. Those are just some indicators."SOLID LIFTERS MATTER"- Top
The car does not have a rear sway bar and the front is 0.75 inches. It also appears to have original AC...which I understand was not offered with big blocks?- Top
At some point in this era the engine designation code became part of the Vin..... don't know when that started but it's worth checking out- Top
3/4" front sway bar and no rear sway bar are small block attributes. What is the rear end code?- Top
In Appreciation of John Hinckley- Top
Nick------
The car in question is an original small block car. No doubt in my mind about it, at all.In Appreciation of John Hinckley- Top
The rear end code indicates whether the heavy duty caps were on the rear from the factory. Also the code would show whether the ratio was typical of a LS -5 or an LT-1.- Top
