66 327/350 camshaft removal - NCRS Discussion Boards
  • Paul K.
    • February 1, 2002
    • 161
    I want to change camshaft while engine is in the vette, does the grille have to be removed?, I know the radiator, and oil pan need to be.
    Paul Klemetson, 37278
    • 6958
    Re: 66 327/350 camshaft removal
    Paul, remove The Radiator and take a measurement of camshaft and what you have for space in front. I have have replaced many buy not in a corvette.I would think there may be enough room.
    • Leif A.
      • August 31, 1997
      • 3654
      No need to remove the grill.
      Leif
      • Edward D.
        • October 25, 2014
        • 206
        The cross X in the radiator support on a standard non-AC car will be in the way so you need to remove the support in addition to the radiator. If an AC car (no X brace) you can leave support in but you do have to remove the radiator and condenser. No need to remove grille.
        • Paul K.
          • February 1, 2002
          • 161
          Thanks for the quick reply's, I was hoping not to remove the grille
          • Mike T.
            • January 1, 1992
            • 569
            My 65 396 Roadster had a flat cam and that X-brace was right in the way. Since I preferred to not deal with the core support, I hooked up my cherry picker, dropped the exhaust pipes and removed the passenger side motor mount bolt and raised the engine a couple inches. That allowed me 'just' enough room to clear the X-brace. Id suspect a smallblock would hit the X brace in about the same area.
            Mike T. - Prescott AZ.
