65 sitting low in rear - NCRS Discussion Boards
  • Frank D.
    • December 27, 2007
    • 2703
    Re: 65 sitting low in rear
    I sometimes do one of those doubletakes when looking at the wheel arches and height...then I always go back and try to sight along the rocker panel to see how parallel it is to the ground for a sanity check and that usually clears things up.
    • Michael G.
      • November 12, 2008
      • 2157
      Mike
      • Tom D.
        • September 30, 1981
        • 2134
        Mike: Are all your trailing arm shims still in place?
        Or, are they held in with a cross bolt?
        https://MichiganNCRS.org
        Michigan Chapter
        Tom Dingman
        • Frank D.
          • December 27, 2007
          • 2703
          Originally posted by Michael Garver (49693)
          Sometimes when I turn, then stop the car, the rear suspension doesn’t necessarily spring back immediately, it seems to stay compressed on one side for a while. Don’t know why, but I’ve noticed it several times on several of my C2s. If anyone knows or can explain this, I’d be interested to hear.
          I can't explain it, I don't experience it and it doesn't seem normal.. Next time you think you see it rock the car up and down by the bumper and see if it makes a difference...
          Unless something is over-torqued or damaged on one side, the suspension should stabilize to normal ride height..
          • Michael G.
            • November 12, 2008
            • 2157
            Shims are intact and tight. No bolt.
            Mike
            • Michael G.
              • November 12, 2008
              • 2157
              Mike
              • Andy C.
                • April 1, 1998
                • 119
                Mike,
                If it bothers you I'll take the car!!!!
                Andy
