Thermostat Housing #60536065 - NCRS Discussion Boards
  • Michael M.
    • February 1, 1993
    • 606
    I have a cast iron thermostat housing that has the number 60536065 stamped on the underside. Does anyone know the year and application this housing was used for?IMG_1762.jpg
  • Michael M.
    • February 1, 1993
    • 606
    Re: Thermostat Housing #60536065
    Is this thermostat housing for a big block or small block?
      • 43285
      Originally posted by Michael Mytro (22211)
      I have a cast iron thermostat housing that has the number 60536065 stamped on the underside. Does anyone know the year and application this housing was used for?[ATTACH=CONFIG]100989[/ATTACH]
      Michael------
      I don't think this is a GM part. Certainly, the numbers on it are not GM part numbers
      • Michael M.
        • February 1, 1993
        • 606
        Joe, the research I did came up with 1965-72 BB Chevrolet 396/427 Camaro, Chevelle, and Corvette. It seems like they split the number #6053 6065 in two parts only using #6053. Maybe this is just a casting number. I asked the question here to get a more definitive answer. Thank you for your response.
          • 43285
          Michael------
          No Chevrolet V-8 engine, Corvette or otherwise, that I am aware of ever used a CAST IRON outlet of this configuration. Many 1966-73 Chevrolet V-8 engines did use an ALUMINUM outlet of a similar configuration. This may be an aftermarket, cast iron copy of that outlet or an aftermarket outlet for some non-Chevrolet application. As I mentioned, the cast-in numbers are not GM part numbers and they do not appear to me to be even derivatives of any GM casting or part number.
